4.2 crank/rods/pistons in a early non roller cam 3.8 v6 block ?
subgunmike
Ga
Does anyone here know for a fact that a 4.2 crank/rods/pistons will fit in a early (82- 87) non roller cam 3.8 v6 block ? I have read and been told by "experts" that yes it will work and no it will not work. Looking for info from someone that has tried it and has first hand information on the swap.
Thanks
  • Sponsors(?)
90sickfox
I didn't really have an issue with the stink...
SN Certified Technician
Mar 2, 2015
5,302
4,351
203
42
I don't know for sure....but I do know that the early 2000 mustang 3.8 engines and transmissions are a direct swap...minus trimming the shifter hole about 1/2 inch. As cheap and plentiful as the early 2000 mustang v6s are in the JY I don't know why you would use the early 3.8.
The 4.2L stroker from a 3.8 interested me for a little while....until I found out how expensive it could get to be. I had a 84 3.8 mustang at the time. Cheaper to swap good 302 in it. More power and easier to find parts.
subgunmike
Ga
Thanks for the response, yeah I know other engines will bolt in but its not a piece of cake. I have a 1997 4.2 block and internals. None of the accessories will bolt up so I'd have to find p/s, alternator, a/c , etc and get that all worked out. Going to a 302 I'd just be better off getting a GT so I'd have the better brakes / rear. I wanted to keep it simple. This car is super clean and all original(to bad it wasn't a gt). It runs great, except for a rear main seal leak it really doesn't need anything. I'm not looking for a hot rod but I figured since I had the crank and rods I'd throw them in to get a bit more power if it will fit.
On another note, can anyone confirm the 3.8 has 1.6 rocker arms ? I believe the 4.2 has 1.7 and I am thinking of swapping the 1.6 for the 1.7's. Has anyone done this with these engines.
Thread starter Similar threads Forum Replies Date
5 Expired 306 Short Block A4 Block/carrillo Rods/je Pistons/forged Crank/edelbrock Intake Engine and Power Adder 0
Rickyll7 Expired Forged Manley Stroker Pistons, Rods, And Crank Engine and Power Adder Parts 0
S 86-95 308 roller engine stock crank, rods, +40 keith black pistons Engine and Power Adder 0
fords2fast4u Who knows about rod/piston/crank specs? Fox 5.0 Mustang Tech 21
Slow5.0 Need advice for good rotating assembly (piston,rod,crank)............ 1994 - 1995 Specific Tech 4
Bad92GT using stock pistons w/331 crank and rods Fox 5.0 Mustang Tech 2
T What pistons, rods, and crank to use? SN95 4.6L Mustang Tech 38
F what do i have to do to get the piston rod off the crank?? **pic** Fox 5.0 Mustang Tech 7
wsbrigham Roush Rebuilding '01-S/C: Any Suggestions for Pistons, Rods, Crank, etc.? Special Production 5
G Will I pass Cally emissions with low-compression crank/rods/pistons? SN95 4.6L Mustang Tech 15
Jason 302 Which stroker crank/rod/piston combo? (351) Fox 5.0 Mustang Tech 9
Marc2 I need decent pistons for a stock block/crank/rod 306 rebuild..... Fox 5.0 Mustang Tech 7
thumper460 Expired 4.6 Steel Crank H Beam Rods Teskid Aluminim Block Engine and Power Adder Parts 3
TurboX2 Dart 302 block, forged crank, rods, etc., etc... Engine and Power Adder 5
Sleeper5.0 347 Stroker Crank/Rods and block clearance Fox 5.0 Mustang Tech 2
J R 302 block/ 331 eagle rods/crank Engine and Power Adder 0
N SOLD 4.6 Rods/crank Engine and Power Adder Parts 2
Y Teksid block, H beam rods and cobra crank for sale Engine and Power Adder Parts 8
jammer84_03 331 rod crank sizing Fox 5.0 Mustang Tech 1
L Rebuilt 4.6L sohc (heads/cam/crank/connecting rod etc) SN95 4.6L Mustang Tech 8
C When it comes to cranks and rods, what exactly tod 4340 mean?? Fox 5.0 Mustang Tech 3
jb1dsl Can you use stock rods with a 3.25 crank Fox 5.0 Mustang Tech 4
SoCalCruising Chevy rod on Ford crank? Classic Mustang Specific Tech 8
OrangeMustangGt 1989 351....Rods/Crank 1994 - 1995 Specific Tech 3
speadfreak rod journal resize on crank? Fox 5.0 Mustang Tech 1
poonstang90lx Eagle crank&rods what kind of RPMs Fox 5.0 Mustang Tech 6
D My V8 crank & rods are done... 1996 - 2004 SN95 Mustang -General/Talk- 3
D bad rod or crank bearing???/ Fox 5.0 Mustang Tech 6
E Electrical Cranks but no spark Fox 5.0 Mustang Tech 3
T No power to the MAF Sensor 1996 - 2004 SN95 Mustang -General/Talk- 0
D 2001 Mustang GT will crank but not start SN95 4.6L Mustang Tech 3
D 93 2.3 crank but no fire 2.3L (N/A & Turbo) Tech 18
C Foxbody with no start issues Fox 5.0 Mustang Tech 5
C 2016 Mustang V6 will crank but not start 2015+ Specific Tech 2
H 8 bolt crank to 6 bolt crank swap???? SN95 4.6L Mustang Tech 1
79pace 82GT Does not Crank the Starter with the Key 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
T Cranks but wont start 2.3L (N/A & Turbo) Tech 4
K Engine 89 mustang lx 2.3 Starting problems 2.3L (N/A & Turbo) Tech 8
D 95 mustang 5.0 no crank no start, went thru checklist.. 1994 - 1995 Specific Tech 1
H My 93 Ford Mustang won’t crank it has fuel but won’t crank Fox 5.0 Mustang Tech 3
Cameron96 Engine Fox engine swap - cranks, fuel, spark and no start! Fox 5.0 Mustang Tech 3
M 1985 Mercury Capri 302 5.0L cranks but wont start Fox 5.0 Mustang Tech 2
BNF861 Vortech Underdriven Crank Pulley Belt Size 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
Xkuzme1 Engine Spout Question. Fox 5.0 Mustang Tech 19
S 72 electrical problems (click no crank) Classic Mustang Specific Tech 1
M CCRM, PCM, or something else? SN95 V6 Mustang Tech 25
TexasFireman Forced Induction Crank Trigger Clearance Issues Vortech Fox 5.0 Mustang Tech 4
John Dirks Jr Stock crank pulley 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
Jacobhollis New to me Mustang, having problems with key/cranking 2010 - 2014 Specific Tech 1
P 2003 mustang GT cranks but doesnt start 1996 - 2004 SN95 Mustang -General/Talk- 3
