TheSubHumans
- Jun 19, 2005
- 5
- 0
- 0
I say if your planning to stay naturally asperated stick with the windsor platform because it seems easier to build N/A power on the pushrod windsors than the modular cammers.
BUT if you have any plans to add boost later on go with the modular motors, the forged Cobra internals can be had for fairly cheap and as was mentioned earlier are good for around 800hp. Once you beef up your internals you can easily make 1k horsepower with stock block, heads, cams, etc. VT engines just built a single turbo 5.4L DOHC 1500hp motor with stock block, heads, cams, etc.
This a good debate on Turbomustangs about windsor vs. modular for boost:
http://www.turbomustangs.com/smf/index.php?topic=58581.0
Just my .02 cents
EDIT: Also, i've seen '67 and up with modulars with stock shock towers and it was a tight fit but i'm not sure how the fit would be pre '67 because the shock towers are closer together...
Just my .02 cents
