4.6 Tech Important Threads (NEWBIES, HERE FIRST)
Spreadman
two wheels
Houston, TX
users.ev1.net
OK peeps. We're getting way too many stickies. So I'm consolidating them into one thread. I will leave this locked so that only mods will be able to add to them. If you see a thread as being genuinely informative, PM me and I'll consider adding it.
General Infomation
1996 through 2004 Technical Service Bulletins
Ford EEC Codes
4.6 2v intake manifold extended coverage !!!
Your 4.6 liter blower combo/setup
Wheel and Tire offset calculator
3.73 videos in daily driving
4.10 videos in daily driving
Modification Survey Thread
List of FAQ Tech threads, start your search with the search button, or start looking here
Drivetrain
1996 - 2004 rear end build
Tremec TR3650 Problem thread
Transmission Cooler installation for the 4r70w by 03ghoststang
How to install wheel spacers by CobraRed_96_GT
SLP Line Lock by propellerhead
How to Install Gears by 03ghoststang
Another gear installation thread by Slider
Electrical
Pictorial Guide to Odometer Gear Replacement by Jinx102672
Traction Control Switch Bulb Replacement by SmokeyLa
How To: Change Your Cluster to Blue L.E.D.s/Incandescent bulbs for $8 by AmBo
Engine
2V Cam Install by Mustang92
Accufab 75mm TB/Plenum Install Write-up by helty
Replacing the AC Compressor Clutch by COramprat
PI Intake Manifold Replacment by -=NightHawk=-
PI Headswap Write-up by 5spd GT
NPI-PI Cam/Manifold Swap by Dusstbuster
PI Intake Swap Parts List by Scrody96GT
How to prevent spark plug blowout by svttech76
Installing a vac/boost gauge by kalvick
PLEASE READ BEFORE YOU REPLACE OR ADJUST A TPS by svttech76
bleeding cooling system by svttech76
In car service of Timing Chain on the Ford 4.6L Modular V8
Exhaust
Debate between H or X midpipe
Polishing Exhaust by 04sleeper
Suspension
Suspension guide by tomustang
Weight Reduction
Rear seat delete - DIY by -=NightHawk=-
oh yeah, since I get asked this about 30 times a week, here's a pic of the IAC valve.........
Reactions: Cameron Reyes
