I gave $ 1900. for the 5.4 . The engine is a ford take out and was complete alt,inj everything needed to be a drop in . I started pulling the 4.6 last nightGoBabyVroommm said:If you can your cams wouldn't it help make the 5.4 at top end. I personally like cams mid to high. I don't like all the power at a low rpm.
What are you doing about the intake? I read that the intake is way too tall to fit under the hood and the stock intake is doesn't fit, so you need adapters or a custom intake.HELLCAT_120 said:I gave $ 1900. for the 5.4 . The engine is a ford take out and was complete alt,inj everything needed to be a drop in . I started pulling the 4.6 last night
I think the oil pan and valve cover on the right bank are the only things that I will need to swap . I am not sure how many small problems will show up but I will keep a log and post it when this project is done .
Hellcat
Black96VertGT said:What are you doing about the intake? I read that the intake is way too tall to fit under the hood and the stock intake is doesn't fit, so you need adapters or a custom intake.
Thanks manBullittStangV8 said:claytucc: man i like that guys trunk...filled with a bottle. your car is pretty damn nice bro
Mike
HELLCAT_120 said:
I am going with the sohc, I think that the dohc engine would have been more of a project than I wanted to tackle . With the sohc the computer , and harness will stay the same with only minor mods . The upgrades I have already done will transfer over , TB. MA. ect . this would not have been the case with the dohc engine . I feel like the money I saved in parts for the dohc will buy me enough mods to get the same type of numbers out of the sohc .
HELLCAT[/QUOTE]
What else would be necessary for those of use 2v folks who are thinking about a 4v swap?
Black96VertGT said:What else would be necessary for those of use 2v folks who are thinking about a 4v swap?
Yes, I read it and it is a great help, thanks.new22003 said:Is the article I posted not showing up or are people not reading it? It says that a 4.6 intake can be used and was used with spacers and that even with the spacers it will fit under the stock hood.
They fit the 5.4 with a 4.6 intake and the spacers under a stock 99 gt hood.
If you read the post, HELLCAT_120 said nothing about what HE was planning to do about the intake. So I was asking HELLCAT_120 to tell us which of the options HE was going to go with. Sorry if that wasn't clear.HELLCAT_120 said:I think the oil pan and valve cover on the right bank are the only things that I will need to swap.
I have a 1996 4.6 2v and want to put in a 5.4 4v.jadesville said:you have a 4.6 2v and want to a 5.4 4v or a 4.6 4v swap?
Black96VertGT said:I have a 1996 4.6 2v and want to put in a 5.4 4v.
Yes, I did, thanks. The difference is that he started with a 97 Cobra, already 4v.jadesville said:Did you read the 5.4 bible at corral?
http://www.corral.net/forums/showthread.php?s=&threadid=10896
It should have basically everything you need to know about the 5.4 4v swap, and if your going that way, go with the navigator engine and not the one from the van![]()
Black96VertGT said:Yes, I did, thanks. The difference is that he started with a 97 Cobra, already 4v.
No worries. I'm sure the answer is out there somewhere, but it can be a real pain finding it because it takes forever to weed through all the hits that end up being about something completely different. LOLjadesville said:sorry for my ignorance, search corral.net, they have tons of threads on the 5.4 swap there.. and alot being the 4.6 2V to 5.4 4V, i would look there for the specific info on computers, wiring and stuff![]()
Let me start by saying that I make no claims as a wrench . I am just a idea type of person who has good problem solving and poor spellingBlack96VertGT said:No worries. I'm sure the answer is out there somewhere, but it can be a real pain finding it because it takes forever to weed through all the hits that end up being about something completely different. LOL
: skills .
