4.6L GT clutch/manual transmission behavior
sharpright
9
Mars
Hello, I am having some issues with my mustang. For those who own a manual 4.6L mustang, can you creep forward or backwards (slow speed in traffic or parking) with just the clutch or do you have to give it gas? Thanks
Depends on the idle. Generally mine will move forward or backwards just by slowly disengaging/engaging the clutch but mine is idled a little high due to cams.
Do you remember if you could move using clutch only before changing the cams? I just want to know if it’s normal for a stock car to struggle and shake as badly as mine does when trying to move with using clutch only. Is it ok to adjust the idle on a stock throttle body?
on perfectly flat ground with 3.27s I was able to get my stock 2003 GT moving without any gas, if I was easy on the clutch. It might shudder a bit, and sometimes heard clutch chatter, but I could get it done. Was easier to use the gas pedal
idle is computer controlled and non-adjustable without a tune.
Are 3.27s stock on a newedge mustang GT?
