4 banger tranny swap
has any body done a 4 banger 5 speed tranny swap on a v8 i've got a 88 gt and some people have told me that it would make a world of difference,what do you have to change to do it and what is the code for the tranny is it a t5e any info would be helpful thanks
i use a 4 cylinder transmission as my backup just incase i break the good one i can still drive my car till i get the trans fixed here is the tranny codes from the metal tag on them.:nice:almost forgot ive heard it will only take about 260 ft lbs of torque i am easy on mine i dont want to have both of them broke at the same time. the 4cyl trans seems alot different than my 5.0 trans.also it has a different pilot bearing size i got a brass spacer pressed on the pilot shaft to make up the difference:dead:
I had a 4cyl T5 behind my 351 in my 68 for several years and I loved the lower gears. I liked it better than the v8 T5 I have now.
I stripped the half of the teeth off 2nd gear, so I had to replace it lol!
they hold just as good as a regular t5, they are wicked though, it seems like it puts the engine right where it needs to be at every shift, i love it!!! Btw: you need a different pilot bearing for the swap, I blew up my v8 t5 so i swapped it with this one and it rocks!!
4cyl trannys cant handle the power of the 5.0 combined with the abuse we all give them
hell the WC T5's that come stock in 5.0's can easily break behind a stock motor...
they are the same tranny. Some of them have 2.95 first gears.
I ran a 4 cyl tranny for over and year gave it the same amount of abuse has one that comes behind a v8, it lasted long than any tranny i've had in my car.
My buddy swears by them...and a huge part of how strong his old coupe ran is because of the extra get up and go he gets from the steeper gears.
DON'T quote me, but i'm 95% sure the pilot bearing you want is from a '78 Mazda pickup truck....and i'm not even kidding. We went to Pep Boys with the V8 bearing and they let us pick through all the bearings they kept in stock to find one that we could use that didn't need the washer like mentioned above, and it ended up being out of a '78 Mazda truck. I would advise you try to do something similar and match them up before you buy, but i'm pretty sure that's what we used.
i had a 4 cylender tranny in my car and i blew 3rd and 4th gear, i was wondering what gear ratio to put back in it!...or if i should bother and jsut look for a 8 cylender trans?
you should have it rebuilt with better gears put in it with 2.95 first. 3.97 first with 4.10 gears is low as in barely any gas and shift.i only have 3.08 gears and it makes it like that
I wouldn't advise running a 4 banger trany with 4.10 gears in a street car (ask how i know..lol). It's a hell of a lot of fun and you'll go through tires really quick, but it'll be a handful at the track to keep from spinning!
I put in my 91, car has been running great for almost a year now. I show no mercy, especially now with the pro 5.0 shifter, I shift with confidence!
This tranny has been the best tranny I've had in the car as of now, and I've had 3-4 in it.
As long as you hit every gear and don't miss gears....they're not as weak as people say they are. A lot of the opinions you'll hear are from people who've never really ran one and just think because it's labeled as a 4 banger trany that it MUST be weak. Well, i wouldn't say they're any better than a V8 T5, but i've also seen 10 second cars on stock T5s. It's all in how good you can shift, but i'd say they're ALL on borrowed time.
Yes, they are ticking time bombs. Not everyone has the cash to dump on TKO 500's - 600's. Hopefully this 4cyl T5 lasts till I can. I have bad wheel hop problems right now, so I don't really gun it in 1st.. I roll into, and once I get in 2nd I put my foot down. That seems to be the only way I can get it to not hop. If I get a set of quad shocks, it'll be awesome to just side step it at like 4 grand in 1st. Actually with how low geared this tranny is I can roll in 2nd at about 30 mph and stomp on it and spin 255/60/15's pretty good.
Don't fear the 4cyl T5's, they are will last a decent driver atleast a year.
Hell my buddy ran one for 3 years and beat the hell out of it every time he drove it. That said, he's one of the best 5 speed driver's i've seen and never misses a gear. It's all about luck really. His car ran mid 13s all day spinning the hell out of the tires.
if you have any kind of gears it would be useless!! mine has 3.08's in it and the 3.97 first in the 4 banger trans, it makes for alot of fun!!! dont even attempt to even try to get it to hook up, it wont happen, at least not on the street, if you have a decent hci steed, 1st and second will be useless!!
Yeah....my buddy ran one with 3.73 gears, and i think he actually made his quickest pass by starting in 2nd and was in 5th crossing the line.
