How can you tell which you have? I have a custom build engine...is there something to look for on the engine itself that will tell you?
thanks!
thanks!
He's talking about the main bolts you'd use studs for. Ours have two main bolts and 2 side bolts. You have 2 main bolts. But the side bolts are what go first not the mains if im not mistaken.ok...with that, maybe you can help some. I am in the process of getting a Vortech V2, SQ installed...I have a 302 stroker with forged internals, Kellogg Crank...and the owner asked me how many bolt main I had.....I want to run approx 10-12 lbs of boost...he said that may be too much with a "2 bolt main"
any thoughts?
Thanks!
any thoughts?
Thanks!
any thoughts?
Thanks!
any thoughts?
Thanks!
find another engine builder, he thinks you have a 5.0 ohv engine. Stock SOHC 2v engines have 4 bolt main and the DOHC 4v blocks have 6 bolts.
I don't quite know the specs. Have they been posted? Cobra crank? ARP main studs? Stock side main bolts? ARP headstuds? What type of pistons? Dish?Thanks guys...this was a schmuck that worked there...not the owner...the owner is legit...this guy I guess just didn't have a clue..
Ok...to further the question...since you guys aced this questions..
I know this has been asked over with a stock engine..but with the forged internals on my build...how many pounds of boost would you say are safe to run with the Vortech?
How many pounds can I go until I have to upgrade the rib pulley system?
Thanks!
Thanks!
+1. Fuel system and type of fuel. I'd recommend some race gas added to 91 13psi and over on 9.8:1. May need a SCT BIg Air from pegging out a LMAF 90mm around 450-475rwhp.With a built bottom end, the amount of power you can make will be based on your fuel system.
If it was me and I didn't want to buy all that stuff I'd stop at when the 90mm maxed. That way you could still use a S-trim, maybe a single focus pump for cheap and a cheap MAF. Otherwise I'd say buy a T-trim or Novi 2k and actually build some power. You'll need to be pulling timing and running more octane than most to hit high boost - although 9.8:1 isn't too hard to work with.
