4 Cats?
stingeragent
33
Lubbock, Tx
Hi, Just had 40 series flowmasters put on my 94 stang gt, and they aren't very loud at all. The guy at the shop told me it was because I had 4 catalytic converters. I see the 2 ones off the H-Pipe obviously, and are the other 2 those ball looking things that the headers go into? Also, how can I check to make sure they are truly 40 series and not some other series?
My catted X sounds much louder than stock and meatier too. I got the flows first and it was deeper, but it didn't change the volume. Now the volume is turned up a lot, though my neighbors don't seem to mind.
Flows are nice, but better when you can get more air through them. Definitely get something aftermarket for a mid pipe.
Ah, That explains it then. I was just kinda worried he didn't install em right or something. Would it be cheaper to get a new h-pipe or take off those pre-cats? Also, which setup would give me a better sound, off-road H and the precats, or h/w cats and no pre-cat? One other question, with an off-road H and if I keep the precats, will it pass emissions with just those? And btw, I live in Texas.
stingeragent said:
So basically, I just need to get a new H-Pipe w/ or w/out cats and that will take care of the pre-cats and possibly the normal cats if I go off-road pipe.
When you buy an aftermarket mid-pipe, it replaces everything between the headers and the mufflers. If you get an o/r pipe, it will not have any cats anywhere. And it will be loud. As for the Flowmasters, when I got mine welded in way back when, they were quiet and crappy. But after a month, they started sounding better and better. I had them on for about 4 months before I did my h-pipe, and they kept getting better. So either give it time, or just throw an o/r h-pipe on and be done with it.
