4 cyl vs GT suspension
  • Thread starter Thread starter smoothmouth1962
  • Start date Start date Apr 30, 2011
smoothmouth1962
  • Apr 30, 2011
Im was just wondering if there was a difference between the suspension in a 4cylinder fox body and a GT mustang. Front and rear suspension.
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Apr 30, 2011
  • Apr 30, 2011
Yes
Shocks, springs, sway bars, struts are different, as well as the front brakes being smaller.
Factory LX 5.0 cars have exact same components as GT
smoothmouth1962
  • Apr 30, 2011
Mustang5L5 said:
Yes
but as far as frame width and lower control arms everything is the same? for instance, could i use a tubular k member for the 4cyl? and put gt rotors and struts and sway bars in? and the spindles? are they different?
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Apr 30, 2011
  • Apr 30, 2011
Yes you can.
smoothmouth1962
  • Apr 30, 2011
Mustang5L5 said:
Yes
Mustang5L5 said:
Yes you can.
well then. the rear suspension is the same? i know the rear ends are different... but could a gt rear end go in?
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Apr 30, 2011
  • Apr 30, 2011
Yes, the only thing you'll need tp add are the quad shock mounts. But an 8.8 will bolt right in. You just might need to relocated the brake line on the body slightly
smoothmouth1962
  • Apr 30, 2011
alright. well the plan is to shove a 351 cleveland in there. ive got the cleveland in a 62 chevy truck haha. i did that about 2 summers ago. but that truck is just so heavy. i need to go faster. theres a 92 fox without an engine or trans for $100 i can get my hands on. so.. i dont know if i should go with that or wait and get a gt or lx body... any suggestions?
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Apr 30, 2011
  • Apr 30, 2011
Well, think of it this way.
LX 5.0's are nothing more than 2.3L LX's with the 5.0 drivetrain and suspension added as a package. When equipped, there are ZERO differences mechanically between the two.
In other words, whatever you can bolt to a LX 5.0, you can bolt to a 4-banger fox.
smoothmouth1962
  • Apr 30, 2011
alright then. sweet. i guess ill pick up that 92. thanks for all the advice
J
junkyardwarrior
Well-Known Member
Jan 10, 2011
400
113
63
Apr 30, 2011
#10
  • Apr 30, 2011
  • #10
K member is different (V8 has wider control arm mounts)
rotors are different (V8 rotors are bigger/better)
front spindles are different
struts are different (V8 mounting point is narrower)
sway bar (front) is different (bigger than 4 cyl)
sway bar bushings are different
calipers are different (V8 calipers are better)
brake lines are different (not a huge issue but they are different)
rear sway bar is nonexistant on 4 cyl cars
no quad shocks on 4 cyl cars
rack is different (V8 rack is quicker ratio than 4 cyl)
and a ton of other stuff is different too.
However....changing from 4 cyl to V8 suspension is not hard.
Swap the brakes, calipers, rotors, struts, K member, spindles, sway bar and rack from a GT or V8 LX onto your 4 cyl car. It all bolts right on. The K-member is not really required but to have it correct, you'd want it. Mine is the original 4 cyl K member but with all the GT suspension stuff & brakes, rack, and better bushings. 4 cyl cars are terriblly boring but with the GT/V8 suspension, they handle a LOT better! Also, because the control arm mounting points are narrower on the 4 cyl cars, if you don't change the rack, you'll definitely need to adjust the toe. Better to have complete alignment done. Mine drives GREAT other than the JUNK struts and shocks that ride like poo.
And the comment about the 4 cyl cars and V8 cars being the same, it's not ENTIRELY true. There's thousands of little differences, from wiring harnesses to clips, vacuum trees, suspension & brake stuff...all kinds of differences. For those of you swapping a 4 cyl to a V8, you're much better off finding a V8 car to start with and selling the 4 cyl car. Speaking from experience!
R
rustyruststang5
151
Ne
Aug 30, 2012
#11
  • Aug 30, 2012
  • #11
i need help im swaping the front suspension from a v8 car to my 4cyl, the only problem i have ran into is the shock mount at the top of the shock tower. it seems that i will have to grind down the hole where the shock goes throu to get it to aline right. is this normal?
fess40
292
Paris, Illinois
Sep 1, 2012
#12
  • Sep 1, 2012
  • #12
I just put everything from an '88 Turbo Coupe on my 4cyl a couple of weeks ago. Should be the same stuff as a GT. I haven't set it on the ground yet or gotten it aligned, but it all fit together nicely. Doesn't sound normal to me.
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
