S sdsteve619 Member May 16, 2011 43 0 7 Orem, Utah Oct 25, 2011 #1 Oct 25, 2011 #1 What is the least expensive way to change the fronts on my 93fb? Can I just go to Auto Zone and buy ??? Thanks!
skunk21 Active Member May 22, 2007 1,203 3 36 Taxachusetts Oct 25, 2011 #2 Oct 25, 2011 #2 http://www.stangnet.com/mustang-for...ug-5-lug-brake-conversion-upgrade-thread.html
S sdsteve619 Member May 16, 2011 43 0 7 Orem, Utah Oct 26, 2011 #3 Oct 26, 2011 #3 Latemodel Resto has the kit for $170.00 however I was hoping I could buy the rotors at Pep Boys or Auto Zone for less IF I just knew the model number? EX: 1992 Ranger 2 wheel drive 4 cyl. or something like that. Thanks for the help.
stykthyn I want to measure mine. It doesn't look that tall. 15 Year Member Jul 6, 2006 5,232 2,652 223 gainesville Oct 26, 2011 #4 Oct 26, 2011 #4 1992 ranger hubs will work. What wheel are you planning on running?
S sdsteve619 Member May 16, 2011 43 0 7 Orem, Utah Oct 26, 2011 #5 Oct 26, 2011 #5 17 by 9 Cobra. I have the rear already finished, just need the fronts now.
S sdsteve619 Member May 16, 2011 43 0 7 Orem, Utah Oct 26, 2011 #6 Oct 26, 2011 #6 Oh was I right about the 1992 Ranger 2 wh dr 4 cy? Or off by a year or something?
stykthyn I want to measure mine. It doesn't look that tall. 15 Year Member Jul 6, 2006 5,232 2,652 223 gainesville Oct 26, 2011 #7 Oct 26, 2011 #7 four cylinder, 6, it doesnt matter. The hubs are the same. Cobras will work just fine. You should be done for under 85 dollars.
O oldfox Member Feb 19, 2009 234 6 18 Oct 26, 2011 #9 Oct 26, 2011 #9 Isn't there a problem with a lot of wheels not fitting the ranger stuff? center of the wheel hits or center caps or something?
stykthyn I want to measure mine. It doesn't look that tall. 15 Year Member Jul 6, 2006 5,232 2,652 223 gainesville Oct 26, 2011 #10 Oct 26, 2011 #10 Cobra r,waffle, and tri bars will fit.
smokin joe Founding Member Sep 30, 2000 746 45 49 Dallas,TX Oct 26, 2011 #11 Oct 26, 2011 #11 You can also use 84-92 lincoln mark VII rotors.
