4 spd vs 5 spd dumb ?
  • Thread starter Thread starter vert06
  • Start date Start date Apr 24, 2007
V
vert06
  • Apr 24, 2007
I hope someone can explain this to me. What is the difference between a 4 and a 5 or 6 speed? Is it just going to the motion of shifting till the last gear or is there more to it? I thought if you are in the top gear then you open up your car to it. It doesn't matter how many gears you have. I am really confused why people put so many emphasis on the tranny if its a 4 or 5 speed. Thanks! I know a dumb question
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Apr 24, 2007
  • Apr 24, 2007
more gears equals more gear ratios. this means that you are in the power band longer. it also promotes quicker acceleration.
with 5 or 6 speeds... the 5th gear is usually an overdrive, and the 6th is usually a double overdrive. this allows great performance, while keeping the ability to cruise on the highways without redlining your motor.
CBus 06 GT
29
Columbus, Ohio
Apr 24, 2007
  • Apr 24, 2007
Having more gears allows you to do 2 things. It tightens up the ratios so you have less RPM drop for each up change and still have a low engine RPM when in top gear for good MPG while cruising down the highway. As bigcat mentioned, the 6 speeds tend to be adding an extra OD ratio rather than tightening up 1-5 compared to a traditional 5 speed, at least that's how the 6 speed in GM F-bodies was setup, meaning that the 1:1 gear is still 4th. I wouldn't be surprised if the 6 speeds in cars like a Subaru STI or Mitsu Evo are tighter with 5th being the 1:1 and only 6th being an OD ratio. I'm not sure how the 6-speed in the GT500 or Viper are setup, but since they are both high HP and high Tq engines, I'm guessing that 4th is the 1:1 with 5th and 6th both being OD ratios.
V
vert06
  • Apr 24, 2007
thank you guys for the response and the explanation. I am very grateful as I am new to the muscle cars. So it is all about more gears as I understand. Very hard to envision if you don't see the inner workings of a car with gears spinning. So it is better in a nutshell that the more gears the better? Thank you again
W
Warlok
89
  • Apr 24, 2007
Didnt your last car have a transmission too? I can see you'r not kidding about this, at least I dont think so. I just cant imagin some one asking this now as if this was the first car he ever saw.
I guess you know that "D" means go "P" means your parked "R" gets you out of the garage, and the other letters on your automatic shifter are there for sport. I bet your a very nice person and I have no dought of that.
Drive slowly.
AznStanger3v
2,026
Northern VA
Apr 24, 2007
  • Apr 24, 2007
these 6 speeds are not the way ol' boy explains the others.
5th gear is kinda like "4.5"
6th being OD or "5th"
ie: 1st, 2nd, 3rd, 4th, 4.5, 5th
thats how the gear ratios are.
V
vert06
  • Apr 24, 2007
I know what a transmission is silly. I know what auto, manual, muncie, tremec. I know tranny has a gears, flywheel, torque converter(auto) and throwout bearing. just don't know of the gears or the importance of gears. Believe it or not I am a good power shifter. Hence the "dumb question" title .
Anyway this would probably be my last post on the transmission. Any chance that we will get 7 or 8 speed. Or is this impossible because as the others indicated that 6 is just an overdrive. I am really getting close to the gear education here. I will google transmission and gears shortly. I really like posting here because of flame free site. The people here are friendly. Again I apologize and thanks, I am not a gear head.
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Apr 24, 2007
  • Apr 24, 2007
According to site rules, we have to be, but...there are several threads I've been dealing with the past week or so that had to have a moderator step in...You'll know it if/when you ask the "wrong" question, not the "dumb" question.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 25, 2007
  • Apr 25, 2007
I had to move this out of tech.
D
D.Hearne
11,730
south louisiana
Apr 28, 2007
#10
  • Apr 28, 2007
  • #10
A transmission with two OD top gears are refered to as a "Double Overdrive" in truckers terms.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
