joshua.y said:OFF TOPIC
What alternator bracket and tensioner is that?
I agree!!Boss 351 said:WOW! I got to say, that's an awsome engine bay, power, looks, everything!
Michael Yount said:And a standard rotation pump, right? Not the reverse rotation that those of us with the serpentine have.....
89sleeper said:Might want to look into an S&B air filter to take advantage of that custom air intake tube like this.
ponyboy19 said:Here are a few pictures of my electric fan set up.. I installed an AFCO 31x19x3 two core aluminum radiator along with the 99-2002 Dodge Viper Gen II electric fan part # 04854720AA. I was told that on low speed the fan will do 3000 cfms and pulls about 25 amps and drops to 8 amps once up to speed.. On high speed the fan will do 4000 cfms and pull about 30 amps and drop to 11 amps once up to speed. The fan is ony 4.5" thick and has 17" blades so it's a pretty thin fan when compared to some like the Mark VIII which would be comparable in cfm output. I installed mine with a 75 amp relay and have it wired to come on high at all times bypassing the low speed completely. It is wired into the low speed wire of the factory 94/95 harness and will come on at the time the low speed OEM fan would have and can be controlled via chip. I also wired in a toggle switch for manual operation if needed. The fan can be bought from a Dodge dealer for about $204 or you can buy them from PDI (305) 218-1486 for $150 if anyone is interested.
Stang8URMPRT said:Uhhh... wire loom is black so you DON'T see it... Blue wire loom man? The car looks tits, but blue wire loop? It's not supposed to be seen.But the fan setup does look sweet!
It's 4.5 thick at the fan motor. Although I had to space it out another 3/16-1/4 inch or so for the blades to clear the radiator. As delivered it's 4.5 at the thickest point including the fan motor. If you have more questions use this post or the other but not both if you would so I don't feel I have to write the same things twiceKiller50stang said:Take a look at this pic. This is what I mean by thickness. This is 4.5" ???
that is actually the tightly taped factory harness that I didn't want to tear down. there is no place else to put it and I'm fine with it right there in plain view. I don't think it looks too bad
On a fox I think it would?UnderPressureGT said:would that fan clear a vortech blower pulley ya think??
on my set up I believe the 8 rib vortech is 4.85 at it's total thickness. Which will not clear on mine, I plan on notching out the front support at some point and moving the radiator toward the front of the car when I get ready to put the blower and a 10-12 rib pulley on it. All I can say is it's 4.5-4.75 thick I'd use the 4.75 since I had to shim the motor so the blades cleared the fan, and the motor will pretty much sit right in front of the pulley. Due to all I have done I'm not a good judge as to whether or not it will for sure clear your setup since mine is quite a bit different.. On a 94-95 with a factory fan I think it would no problem, but the Afco is Much thicker which takes up realstate.
