89CopCoupe said:First point to make is that a 400 horse car can be spanked by a 300 horse car ... power to weight ratio and good traction right![]()
also, if the 300hp motor has a really flat power curve and the 400hp motor is all peak power
NUTCASE said:also, if the 300hp motor has a really flat power curve and the 400hp motor is all peak power
Scorcher2005 said:like previously said, build a good strong n/a motor that can put down 300rwhp by itself. throw a s/c on top of this and stay out of boost (usually 3000rpm+). When you want the power, its there. Even vortech's bottom of the line v1 s-trim should put you at your goal. Good-luck. (by the way, i have similar goals w/ the combo in my sig, 20mpg but only 300rwhp)
Not an option... My truck is a GM, but my car never will be!95cobra50 said:ls2 or 6![]()
LukeDaddy said:Am I the only person that believes that 400whp can be made N/A?
Why not run an all motor setup with a stock crank, I beam rods, and hyper pistons to yield a nice, light rotating assembly, and run some AFR205s or Victor Jrs with an RPM II or Systemax intake and a nice FTI cam?
Top it off with some 36/42lb injectors, and a 255lph pump, along with an MSD setup, and you should be there...
Hell, Ed Curtis makes 325-345whp on a STOCK BOTTOM END with 165s, a cam, and a ported manifold of his choice on street cars all the time?
I would call Ed, at Flowtech Induction, and talk with him about a N/A Motor...
Throwing a supercharger/turbocharger in the mix will decrease the gas mileage... a N/A combo will ALWAYS get better mileage than a comparable boosted motor....
Daggar said:Sure... I get over 20MPG on the highway. In town... a completely different matter. I average between 10 and 11 in town for a normal work week.
Edit: I guess that my point is that there's going to be a trade off somewhere.
Foxfan88 said:Well yes vettes and stuff yeah but EXTREMELY HIGH PERFORMANCE ( like under 12sec E/Ts) and EXTREMELY HIGH FUEL ECONOMY (like 30+mpg) cannot coexist, and if it does then its ****ing expensive
