408 Windsor Stroker
fox04
78
augusta, ga
408 windsor stroker
-eagle forged crank
-eagle forged h-beam rods
-je forged piston. dome pistons approx 14:5:1 compression
-windsor sr alum heads. 210cc 2.02 valves springs good for .700 in lift
-forgot all cam specs but is .688 solid roller (can pull cam to find out)
-1.6 roller rockers, girtles for rockers. Hardly ever had to adjust valves.
-victor jr intake
- manual water pump ,
-block has orings for running copper head gaskets
-has all arp bolts on everything
motor needs one piston. A electric fuel pump went out and the motor went lean and burnt #8 piston. Did not hurt anything else at all! There is a lot of money in this motor anyone who knows about racing knows it. The head, cam , and lifters alone are worth 2500$. For $500 you will have a 7k motor. The motor went high 5s in the 1/8th through a powerglide. I just dont have the time or money to finish my car (school) so im selling everything. I want only $2500 for complete motor intake to oil pan. call or text 706 871 1461 I live in Augusta Georgia
