I finally started putting my 418 back together!
I've got the bottom end assembled and I would have the cam/heads installed but I ran into a problem with the Rollmaster timing chain set
. I guess I need a brass thrust washer, but there's not one with timing set...The cam moves a good bit back and forth and the cam sprocket hits on the cam retainer bolts, but Im guessing the thrust washer will fix that? Anyways, here's a couple pics of my progress from this weekend...
And here's a pic of the cam sprocket. The black ring, which Im guessing is a bearing, is what hits on the cam retainet bolts.
I've got the bottom end assembled and I would have the cam/heads installed but I ran into a problem with the Rollmaster timing chain set And here's a pic of the cam sprocket. The black ring, which Im guessing is a bearing, is what hits on the cam retainet bolts.
