429 Help to 1967 mustang!!!!!!!!!
  • Thread starter Thread starter lookout4me
  • Start date Start date Apr 21, 2005
First Prev 2 of 2
D
danny clemens
728
#21
  • Sep 14, 2005
  • #21
Have you thought about an FE? A 428 with aftermarket heads is very impressive. FE's also came in these Mustangs from the factory.
rbohm
6,698
550
204
tucson,az
Sep 15, 2005
#22
  • Sep 15, 2005
  • #22
the 429/460 fits the 67-70 mustang engine compartment better than the FE motors do. the swap is rather easy to do, and maintenance is easier than with an FE.
67GTA-FB429
777
Tri-Cities, Wa
Sep 15, 2005
#23
  • Sep 15, 2005
  • #23
Aren't the FE engines shorter than the 385 engines? I know in my car hood clearance has been a major PITA. And it came with a 390 many years ago.
Edbert
3,548
32
109
Austin TX
Sep 15, 2005
#24
  • Sep 15, 2005
  • #24
Dimensions on the engine bay of the 67-70 are nearly identical, they ARE identical in most ways. A normal headed 385/Lima motor (not a 429-boss) WILL fit without sheetmetal work, your only gonna need swap parts, start with mounts and exhaust, the rest is even easier.
67GTA, that is backward WRT the block, the 385 series were designed much like the Windsors, the bottom of the block was the centerline of the crank, it did not have "Y" shape from the longer "skirts" of the FE series.
67GTA-FB429
777
Tri-Cities, Wa
Sep 15, 2005
#25
  • Sep 15, 2005
  • #25
huh? what the heck is WRT??
H
HHStang
566
Coastal SC
Sep 15, 2005
#26
  • Sep 15, 2005
  • #26
I'd use the exhaust manifolds and not worry about headers. I have a banged up set (67/429) I'd sell cheap if someone wants them. I'd probably do a pre-73 460 too if you don't already have the 429.
Edbert
3,548
32
109
Austin TX
Sep 16, 2005
#27
  • Sep 16, 2005
  • #27
WRT= "with regard to", at least it does IIRC, LOL.
67GTA-FB429
777
Tri-Cities, Wa
Sep 16, 2005
#28
  • Sep 16, 2005
  • #28
OH. Ok. (now I feel old)
So you are saying that the 385s have a shorter deck height than the FEs?
HH: The exhaust manifolds are a great choice. That is what I have on my car and I am just under 400hp at the wheels. They are a cheaper and easier exhaust solution as opposed to $700 'special' headers.
H
HHStang
566
Coastal SC
Sep 16, 2005
#29
  • Sep 16, 2005
  • #29
Plus the long tube headers bottom out "big time". I have FPA shorties now though.
Edbert
3,548
32
109
Austin TX
Sep 16, 2005
#30
  • Sep 16, 2005
  • #30
I do too, all the time, I'm just used to the "l337 $pe4K o teh intardnet", also known as typing for the lazy
Not authoritative enough on that, I don't even know the relative deck heights but the block itself is generaly a larger verion of the windsor (260/289/302/351) style of compactness, whereas the FE was a new version of the "Y". I was trying to find good illustrations of this on the web but got tired of looking and I can't draw it in ASCI so let me try words...
The lower portion of the block on the FE series used the heavy cast iron skirts that came straight down from the cylinder walls to the pan rails PAST the centerline of the crank. This gave them great strength (also allowed for cross-bolting the main caps) but also great weight. The 385s (and 335s) used the more modern (at that time) method of "thin walled casting" and stopping the block at the centerline of the crank just like on the Windsors. A Lima-460 block wieghs less than a 360-FE, and has the advantages of canted valve heads (but the heads are larger/heavier) but total engine weight is in the ballpark.
Somewhat ironic is that the truly modern engines (4.6/5.4 SOHC/DOHC) have gone back to a long skirt design and although they have small displacement they are larger than a 429 Boss!
Edbert
3,548
32
109
Austin TX
Sep 16, 2005
#31
  • Sep 16, 2005
  • #31
I found this and don't think it is authoritative but is still interesting:
Ford flathead V8 525
Ford flathead V8 569 ('53 239 CID)
Ford 4.6 SOHC 530 (iron block aluminum heads)
Ford 4.6 DOHC 525 (aluminum block and heads)
Ford 255 Windsor 468
Ford 289/302 V8 460 (late 5.0s are a bit lighter)
Ford BOSS 302 500
Ford 351 Cleveland 550 (includes BOSS and Australian 302-C)
Ford 351 Windsor 510
Ford Y block V8 625 (272-312 CID)
Ford FE big block 650 (332-428 CID)
Ford FE big block 670 ('59 352 CID)
Ford 429/460 V8 640
Ford BOSS 429 680 (iron block, aluminum heads)
67GTA-FB429
777
Tri-Cities, Wa
Sep 16, 2005
#32
  • Sep 16, 2005
  • #32
Is that the weights of the engines?
Edbert
3,548
32
109
Austin TX
Sep 16, 2005
#33
  • Sep 16, 2005
  • #33
Yes.
Sicarius428
2,085
Sep 16, 2005
#34
  • Sep 16, 2005
  • #34
I can't find an exact weight of the 428 FE vs. 429/460 weight because they all vary from source to source. This point comes up every now and then. I was always under the impression that the 429/460 was heavier though it was intended to be lighter than the 428. When you are getting into the heavy weight class of engines... I doubt it will matter much either way... Should be a nonissue.
Kevin
First Prev 2 of 2
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
J
Mustang 1968 coupé restoration hvac
  • JackStang68
  • Mar 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
