danny clemens
- May 4, 2005
- 728
- 0
- 16
Have you thought about an FE? A 428 with aftermarket heads is very impressive. FE's also came in these Mustangs from the factory.
Edbert said:............
67GTA, that is backward WRT the block, the 385 series were designed much like the Windsors, the bottom of the block was the centerline of the crank, it did not have "Y" shape from the longer "skirts" of the FE series.
67GTA-FB429 said:OH. Ok. (now I feel old)
Not authoritative enough on that, I don't even know the relative deck heights but the block itself is generaly a larger verion of the windsor (260/289/302/351) style of compactness, whereas the FE was a new version of the "Y". I was trying to find good illustrations of this on the web but got tired of looking and I can't draw it in ASCI so let me try words...67GTA-FB429 said:So you are saying that the 385s have a shorter deck height than the FEs?
Ford flathead V8 525
Ford flathead V8 569 ('53 239 CID)
Ford 4.6 SOHC 530 (iron block aluminum heads)
Ford 4.6 DOHC 525 (aluminum block and heads)
Ford 255 Windsor 468
Ford 289/302 V8 460 (late 5.0s are a bit lighter)
Ford BOSS 302 500
Ford 351 Cleveland 550 (includes BOSS and Australian 302-C)
Ford 351 Windsor 510
Ford Y block V8 625 (272-312 CID)
Ford FE big block 650 (332-428 CID)
Ford FE big block 670 ('59 352 CID)
Ford 429/460 V8 640
Ford BOSS 429 680 (iron block, aluminum heads)
