460 question
water pump pushed the water in the opposite direction that it would normally in a car.
i know of some people that have used boat engines in cars with no problems.
i would assume you would be rebuilding it and buying alot of new parts. which would include a water pump which would be stardard rotation so the reverse flow deal wouldnt mean a thing.
Ready... 475 on a stock head and a small performance cam... 500+ on a set of D0 or C9 heads ported and stock valve size.. 550+ on a set of C9/D0 heads with CJ valves and mild hyd performance cam.. 600+ Hp with the ported D2 Police intercepter heads or CJ/SCJ heads... 750 Plus, getting stupid on the solid cam and 850 Holley!! and thats not all.... dump a 300 shot of NOS and your in the low to mid 8s in the qtr..... freaking awesome......
Just me..............................................
Thumper
Thumper
Thanks man.. How much would you charge to do some head work Hit me with a PM..
nothing like a 460 in fox body realy away to fly my dad has a 89gt with a 466 in with 429 scj heads ported tunnel ram with 2 950 cfm carbs run in the low low low 10s with street tires. all you need to drop a 460 in a fox is the hooker swap headers truck or car oil pan ford racing sells the motor mounts still can use the stock cross member just have to grind the spot weld off it and slide it back drive shaft can use the stock 5.0 need the inport changed to fit the c6 trans with the right set of pistons and truck rod beam polished i seen then trun 8500 1ts to 2sn 3th at 8500 rpms will need no smaller then a 4" cowl to clear it also have to beef up the rear end. runing a 460 in a rollgae is a must it is a tight fit but it clears remember the 4.6 and 5.4 DOCH cam motor fit in the fox thay are wider then a 460 mild cam miled intake with headers thay will make a easy 550hp with 429 cobra jet or super cobra jet heads if its a 1973 460 thay have smog heads on them kinda junk still can make power with them dove c are good set to.
