4cyl to 5.0L Carb
DarkMesa8
1,087
Orlando, FL
I ran a search, but the results were only 4cyl to 5.0L EFI, and 5.0L EFI to CARB swaps.
I checked Fletch's website, which was great! I'll be using that info.
Here's my unique situation, though. My 1991 2.3L is 217,000 running strong, but I'm kind of harsh on the gas pedal and it could blow in a year or less. When it does, I'm putting a 5.0L into it and need to know what is absolutely necessary to get the V8 in and running.
Here's what I can think of that's absolutely necessary
Longblock
CARB and intake
Fuel pump
Regulator
Distributor
T5 input shaft
Bellhousing
Shift Fork
Shift Cable
New Fan
Hoses
Wires
Plugs
Filter
All accessories
Exhaust
Now that's the necessity list, is there anything else?
I'm going to add these to it as money allows, either to the pile of parts, or to the car if the motor blows, will they work?
-5.0L AC manifold, compressor (will the 4cyl condenser, evaporator, and accumulator work?)
-Cruise control, what year vehicle will I need to take it off, and will it work on a carbed car?
-GT T5
-8.8 Rear End
I also have some questions that I need to know.
Will the brakes work properly with the carb setup? Vacuum, etc
What about power steering? The AC itself, does it need the computer left in?
Can I leave the 4cyl computer in to control accessories, even though the motor is carb? I know that I'll most definitely have a CE light, but I could live with that.
The brakes will work as long as all the vaccum hoses are hooked up correctly. Im not sure of this but the 5.0 came with bigger brakes in front(I think).
And another thing to think about is buying the parts aftermarket. IE bigger and better because once you have a 5.0 in her you will already want MORE power. So before you buy stock parts you might want to keep your eyes open for aftermarket and save yourself some cash....
My 95 GT Convertible is my go fast car, I just need a daily driver that can pull out into traffic without danger.
Laser Red 1995 Mustang GT Convertible
Engine: 302ci
Edelbrock Aluminum Performer 5.0 cylinder heads
Crane 2031 cam (.513in/.529ex)
FMS Cobra intake (ported/polished/powdercoated)
1.7 Cobra Roller Rockers
Mac Underdrive pulleys
Mac cold air intake
75 mm Pro-M MAF meter
BBK 65mm throttle body
Summit Racing harmonic balancer
180 degree thermostat
Fluidyne aluminum radiator
Wazee power steering and idler pulleys
Wazee EGR delete kit
FMS high-flow oil pump
FMS windage tray
ARP Bolt Kit
Computer: T4M0
Autologic Custom Burned Chip
Ignition:
MSD 6T Ignition Box
MSD Soft Touch Rev Limiter
MSD 8.5mm Super Conductor Wires
MSD Blaster Coil
Power Adder:
NOS 5115 80/150 Dry Shot
Fuel System:
FMS 30lb Injectors
BBK 255lph Fuel Pump
Kirban Adjustable FPR
Autometer Underhood Fuel Pressure Gauge
Exhaust:
Mac 1 5/8" jet-hot coated longtube headers
Mac 2.5" Prochamber Offroad Pipe
Mac Flowpath Mufflers (Dumped)
Transmission/Drivetrain:
Borg Warner T5 Stock Spec
King Cobra Clutch
FMS 3.55 gears
FMS aluminum driveshaft
Welded driveshaft loop
Suspension/handling upgrades:
Welded full length subframe connectors
Eibach Pro springs
Monroe Sensa-Trac shocks/struts
FMS strut tower brace
