4R70W fit in my 94?
jasonlee0704 said:
Arsonstang, IIRC the only difference between the 2002 4R70W and your AODE is the 4R70W has a wider ratio planetary gearset (which you can upgrade the AODE with) and a mechanical diode which you can upgrade to as well.
doesnt change the fact that there is a different bellhousing, making it not able to be bolted up without an adapter plate.
I agree....AODE is junk compared to 4R....find a 4R from a 3.8 or 4.0 vehical. Then buy the Buemann TCS computer (or tothers) to control it better - oh, and do the J mod for good measure.
