  • 1994 - 1995 Specific Tech
4R70W Shifting Problem
  • Thread starter Thread starter Rodder37
  • Start date Start date Sep 17, 2011
R
Rodder37
Pikeville, NC
Sep 17, 2011
  • Sep 17, 2011
I have a 94 GT with a 4R70W that the previous owner swapped from a 2003 V6 Mustang. My problem is that it is slow to shift from 2nd to 3rd. It is pretty bad when I am getting on it. It seems like a delay....mean time the engine is screaming and when it does shift, the shift is pretty soft. This happens with the OD button on or off.
I don't know what they did when they swapped from the AODE to the 4R70W, but I have read things like the trans needs 2 more clutch plates to make it V8 ready and the computer needs adjusted for the new gears and shift points. I'm still learning about this swap.
Have any of you guys encountered this problem?
Here is the numbers of the transmission in case it might help:
PKE-BC1
1R3P-7000-AA
045677
Bar Code: E-BC1 045677
Thanks for any help on this!
wheelyman19
155
Sep 18, 2011
  • Sep 18, 2011
It's not the same Tranny but my car did kinda the same thing with my 4.10s in and didn't replace the speedometer gear but after I replaced that it shifted sooo much better! So if u got different gears maybe this is the prob Idk just throwing it out there. Hopefully it helps!
R
Rodder37
Pikeville, NC
Sep 18, 2011
  • Sep 18, 2011
Thanks for the reply. I have stock rear gears, but the trans is different. I will look into setting the shift points...... now to figure the best way to do that.
toyman
1,944
54
79
Vernon BC
Sep 18, 2011
  • Sep 18, 2011
Changing shift points is not so easy. You will either need a chip or a different controller such as the Baumannator TCS. Your problem doesn't sound like a shift point issue but rather a transmission that's not shifting properly. While the stock shifts are soft there shouldn't be the long delay you're describing on the 2-3 shift. Not knowing the complete history puts you at a disadvantage as to what course of action to take. Is the fluid at the proper level and does it look red (good) or is it a burnt brownish color (bad)?
R
Rodder37
Pikeville, NC
Sep 18, 2011
  • Sep 18, 2011
The fluid is at the proper level and red, but I'm going to change it anyway. I'm going to look into the TCS and chip while I ask around at the local transmission shops and see if anyone is familiar with this swap. Thanks for the help guys. It is really appreciated!
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
