4v foxbody
RJ Brar
23
Hello guys, just picked up a Lincoln mark viii with the 4v motor for 300 bucks. I’m going to be swapping the motor into my 87 notch. I wanted to get info what I should do to the motor before I throw it in the fox. Like any thing these motors are known for that’s better to change it before I put it in? Motor has 175k on it. I want to eventually sc it. I know if I go the m112 route I need to go with the termi heads. Any benefits of porting the current head? I also have a cobra upper n Lower intake for it. Any other recommendations for power please mention it. Thank you.
  • Sponsors(?)
08GT500
800
113
53
Massachusetts
Hi, Did you get clarification regarding your question, apologies for the late response.
-John
08GT500
800
113
53
Massachusetts
Hi,
Well that’s not good.. What yr is this, 93-98’?
I’m not being cruel here, only realistic.. If you’re going where you are with this, rebuild it. Tekskid motors last long miles, (reasonably cared for), but is now headed for a few levels of mod’s, incl. FI.
The NA Cobra build will probably not have issues, can’t say for certain..who can unless you’ve thoroughly scoped out the motors innards.
No doubt you can get to where you want, I’d seriously consider going through it & seeing what things look like apart.
The 4V head cc’s and pistons won’t allow much room for boost.
The levels of build hinge both on your budget & goals. Say intent is FI. You can buy a reciprocating assembly, fairly reasonably, a cast crank sitting in pristine std.bearings, I beams, Hypereutectic Dish Pistons cc’d for your purpose, long duration Cams & you can spin 600-700HP out of it. Steel & Forged, studded, girdled- 1,000 Hp, or more. Head porting isn’t as much a concern with FI, unless your going for the Fox pretzel twist HP/TQ levels.
If you want to hit it in the middle, do that- so you can do your (2) stages, spend a little less on the Shortblock. Keep the Cams so they’ll work for both FI & NA., etc.
Or, go with the Cobra NA build & build it for that, but a lot better, not be concerned about the bottom end, except that it’s fresh, hate for you to have to rip that motor back out again, due to a part failure.
Do you have more history on that motor?
-John
Thread starter Similar threads Forum Replies Date
M Engine 87 Foxbody Hesitation at High RPMs Fox 5.0 Mustang Tech 0
D 1989 Dash Harness Problems Fox 5.0 Mustang Tech 2
F Advice needed for Foxbody build 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 28
9 92 foxbody front disc brakess Fox 5.0 Mustang Tech 1
T 93 convertible torque box reinforcements 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
B [Project Car] 1986 5.0 V8 Foxbody Mustang Starting Issue Fox 5.0 Mustang Tech 8
S 391 swap into foxbody 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 24
5 Powersteering Pump replacement gone wrong Fox 5.0 Mustang Tech 15
F Brakes Hydro boost foxbody Fox 5.0 Mustang Tech 8
8 Electric fan problem Fox 5.0 Mustang Tech 2
Waz900 Brakes Foxbody SN95 Booster install Question Fox 5.0 Mustang Tech 3
A Car starts but dies Fox 5.0 Mustang Tech 2
8 Coolant leak Fox 5.0 Mustang Tech 4
spiegs throttle cable removal and install Fox 5.0 Mustang Tech 8
C Engine Gray smoke from exhaust. Smells like gas. Fox 5.0 Mustang Tech 15
1hot87gt Love my FoxBody 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
K New Member introduction 1990 Foxbody Hatchback The Welcome Wagon 1
C Foxbody with no start issues Fox 5.0 Mustang Tech 5
E Best tires for 88 Foxbody GT? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
K Is my foxbody cammed? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
White85fox New from Idaho The Welcome Wagon 3
Foxslider SOLD WTB: 87-93 stock foxbody axle out of 8.8. Drivetrain Parts 0
M 93 foxbody 347 stroker megasquirt 2 pnp initial timing set up?? advice Digital Self-tuning Forum 6
S Fuel Explorer Throttle Body.....What Years Will Work On Foxbody Fox 5.0 Mustang Tech 5
12Pack WTB/Trade Wtb foxbody, FL Fox Body Mustangs For Sale (1979-93) 0
S Motor Mounts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
S Old Foxbody owner looking to own again. The Welcome Wagon 4
K What's it Worth? 87 Fox GT What is it Worth?!?!? 11
T Exhaust Replacing cats with O/R x pipe and need a tuner Fox 5.0 Mustang Tech 6
mustangmccance Foxbody owner from Iowa The Welcome Wagon 14
T Aod transmission issues Fox 5.0 Mustang Tech 1
T Aod shifter linkage 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
N 86 foxbody Fox 5.0 Mustang Tech 1
Foxslider Foxbody junkyard direct replacement axles 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 41
T Drivetrain Is it worth it to rebuild an aod transmission or get something else? Fox 5.0 Mustang Tech 18
T Engine Foxbody idling surging and stalling Fox 5.0 Mustang Tech 10
K Engine 89 mustang lx 2.3 Starting problems 2.3L (N/A & Turbo) Tech 11
P Fox Has anyone ever used sn95 emission valve solenoids in a foxbody. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
F Rancho GT-III, Foxbody Mustang Swaybar Parts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
5 NEED ADVICE FROM COMMUNITY MEMBERS 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
T Heater Core fix 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
B Drivetrain Foxbody Rear End Maxed Out Fox 5.0 Mustang Tech 38
5 3.55 gears for a 87 mustang automatic transmission 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
I 1988 Mustang possible transmission shuddle? Fox 5.0 Mustang Tech 4
8 Engine Turbo fox build hot start issue Fox 5.0 Mustang Tech 7
beyondEOD SOLD MOATES QUARTERHORSE QH EEC Tuner Engine and Power Adder 1
1989LXFOX Engine 2G Alternator Install Wiring Help Fox 5.0 Mustang Tech 3
8 Plz Help! ‘88 Mustang will not idle and runs poorly Fox 5.0 Mustang Tech 4
Serb Progress Thread First Foxbody 408 Stroker 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
E WTB/Trade WANT TO BUY: ALMOND FOXBODY Fox Body Mustangs For Sale (1979-93) 0
