Is it possible to swap 4v dohc heads onto a 2v sohc motor? What would all be required...tune, heads, cams, valves, etc? Just a thought, I really think Ford should've put the 4v motor in the Bullitt
yeah you'll need to many parts. heads, cams ,cam covers, timing cover, intake, throttle body and induction system. the list is longer than that but thats the bigger items.
Too many parts needed in order to make it work the right way and correctly
Throttle Body
Intake to match the heads
Heads and cams w/ secondary chains, cover, etc
New pistons as the CR is different
New crank as the 4V is Forged and revs to 6800 regularly
Flywheel to match the 8 bolt cranks
Alternator
Injectors
Harness
A tune
