5.0 Aode Into 57 Wagon Swap Questions
big vic
Active User
Jun 4, 2017
10
Hi I have 57 wagon that I put a 95 5.0 and AODE ino I have the complete doner car and want to hook up all the harnesses so it will be easy to fix or diagnose the Mustang GT was totaled but ran great all the mechanicals of the swap have been done I need help with the easiest way to get it running
This may not be the place for this inquiry, I think I'll move it to the tech thread. Sounds like you got a good jump on the swap, if it helps there are some wiring diagrams for 95 mustangs on veryuseful.com.
took some pics today
  1. the tank pic is the new tanks inc tank with internal fuel pump and braided teflon lines all the way to the fuel rails feed line with a filter and return line both #6 custom tank to fit with fill line mated up to the stock location fuel door
    shifter pic is shifter from the mustang mounted to the trans tunnel i will build a counsol around it
    pedal pic is pedal from the mustang mounted and using the stock cable
    i used the correct belt for AC deleat and a new stock tensioner
    huge be cool radiator fitted into the core support took all night of cutting to make it look good but it look great
    huge cooling fan with relay set up on a switch so i can control the coodown or warmup
    to fit the 95 motor into the 57 frame i needed a 67 mustang pan and oil pickup with front sump to give me the clearance for the steering linkage
    stock headers fit perfectly with only 1 small dent to clear the steering box the passenger side was a perfect fit
    to fit the AODE trans i moved the stock crossmember back 3 inches and welded a plate at the height needed for correct pinion angle
    to mount the stock airbox I cut out a section of inner fenderwell and ran the snorkle into the fender
    i had a custom driveshaft made
    i had to raise the floor in the back to fit the tank but its under the pare tire well and you can till fit a spare i also installed a trap door in the floor to service the fuel pump
    spent all winter on the project working around my 60 hr a week job now all i need is to get the harness hooked up
    the engine harness in on the engine and i have all the wireing and modules from the doner car 95 GT I jut dont know where to go from here i was hoping someone would be able to tell me what to hook up to get it running
    #6big vic, Today at 9:08 PM
    Edit
    + Quote Reply
    DavedacarpainterThat's MISS Susie Homemaker to you mister!
    SN Certified Technician
    OMG, that is so freaking cool!:nice:
Here are some essential diagrams that will help you with the electrical wiring. This is just short list, the actual site has a lot more...
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
TFI module wiring for 94-95 Mustang GT
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-IgnitionControlModule.gif
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 88-90 Mass Air Mustangs
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangEngineHarness.gif
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/TPS_IAB_Pic.jpg
Starter circuit
http://forums.stangnet.com/attachment.php?attachmentid=21328&d=1080916057
Alternator diagram for 94-95 Mustangs.
