5.0 cam upgrade ?
  • Thread starter Thread starter Jeff S.
  • Start date Start date Nov 3, 2008
J
Jeff S.
Bismarck, ND
Nov 3, 2008
  • Nov 3, 2008
I'm putting a 5.0 from a 99 explorer in my 69 mustang. I want to upgrade the engine. What cam would you guys recommend? I read about the E303 and TFS 1 is anyone running either of these? I'm looking for that cool idle sound. I know the valve springs will need an upgrade any other suggestions? Would it make any sense to change to 1.6 rockers without changing the cam? By the way I'm taking the fuel injection off and will be running a carb. I have the gt40P heads so headers will be a problem but I will probably end up with Macs. Any other suggestions would be appreciated.
stykthyn
5,232
2,652
223
gainesville
Nov 3, 2008
  • Nov 3, 2008
I have the TFS1 cam. it's got a definite lope at idle and is a great performer. personally I think it's better than the alphabet cams, but honestly the stock H.O cam makes great power in the explorer motor
88mouse
630
Mooresville nc
Nov 3, 2008
  • Nov 3, 2008
I have run both the TFS 1, and the E . The e cam pulls harder than the tfs. But doesn't have the lope. And I ran the same set of 1.7RR on both cams.
WHT306
104
HUNTSVILLE AL
Nov 3, 2008
  • Nov 3, 2008
I'M RUNNING THE F303 CAM AND IT SOUNDS GREAT AT IDLE. ALOT OF LOPE BUT POWER BAND IS 2800- 6500 RPM BUT I TEAR MY FRIEND UP IN HIGHER RPM WHERE HIS E303 DOESN'T GET IT DONE.
1987stangman
684
24
  • Nov 3, 2008
Get an adjustable timing gear set and set the E-CAM straight up and then advance it 4*, it will lope then and out perform the TFS cam to boot.
Maryland Stang
1,656
30
39
Greenville, NC
Nov 3, 2008
  • Nov 3, 2008
Here's my B cam. Great power!
MySpaceTV Videos: Richards Mustang by Tim Buck
thumper460
3,022
Orange Park , Fl
Nov 3, 2008
  • Nov 3, 2008
The E cam will be the better for your application... and YES!! Advance that sucker.. you will lobe the performance ruff idle and the power will rock!!
Just me...........................................
Thumper
Whats up 87stangmn??
ShortThrow50
923
Pa
Nov 3, 2008
  • Nov 3, 2008
Heres a vid of my cam lope hen i ran a trick flow stage 1 cam
YouTube - Trcick flow H/C/I 5.0 mustang
88mouse
630
Mooresville nc
Nov 4, 2008
  • Nov 4, 2008
i mite try that I like the way it sounds now. Sounds about stock.
I swap the b for the e thats in my car now. The b cam didn't make no power at all.
Maryland Stang
1,656
30
39
Greenville, NC
Nov 4, 2008
#10
  • Nov 4, 2008
  • #10
I've done a bit more to mine to make upper RPM power.
1987stangman
684
24
#11
  • Nov 4, 2008
  • #11
Thumper
Not much Mike, I started to stop by the other day but I did not want to bug ya and I was super tired from work. Heads are jam up!
asecretfile
228
#12
  • Nov 4, 2008
  • #12
Ive had both the e303 and the tfs1 cam and I'd say they both perform great with the e303 pulling a little harder but as far as sound goes, the tfs1 is a bit choppier probably because of the split duration
Here's a clip of my 87 GT with a tfs1 cam, OR Hpipe and mac produmps
car-1.flv - Video - Photobucket - Video and Image Hosting
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
H
1995 cobra engine noise help
  • Holt2010
  • Nov 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 8, 2026
Holt2010
H
