5.0 Conversion To MAF
howie1145
I'm a newcomer when it comes to "new" mustangs, my experience is in classic mustangs (64 1/2 & 67)
I have a '67 Mustang convertible and I am trying to install a engine from an '87 5.0 Mustang EFI use in my class '67 convertible.
I am trying to make it a Mass-Airflow system, I have an engine wiring harness from a '93 Mustang and a A9L computer. The problem I am having is I can't figure out wiring, how to hookup the ignition to sync with the computer so the car will start.
Thanks again for everyones time and help. thanks all !!!
Duplicate the wiring from a 5.0 91 EFI Mustang.
Starter solenoid wiring for 86-91 Mustang
attachment.php
Use 30 amp fuse for two 14 black/orange gauge wires from the starter solenoid to the EEC relay
Use a 20 amp fuse for one 12 gauge wire from the starter solenoid to the fuel pump power relay.
Use a 10 amp fuse for the 16 gauge red/green wire from the ignition switch to ignition coil and TFI.
Use a 10 amp fuse for the O2 sensor heater circuit orange/yellow wires.
Be sure to ground the two black/white wires coming out of the computer to the battery negative cable pigtail.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
