I found someone that is offered an Eibach Pro-kit 2 inch drop for a 5.0 for 80 bucks. I've been wanting to lower my 4 banger for a while, will this work alright? I believe that the 2.3L is only about 50-100lbs lighter in the front, I dont really assume it will ride high in the front by just that little weight limit... a bare 302 carbed fox with drop springs dosent ride high in the front, so my loaded 2.3 should be fine in theory... right?
I assume it will be quite a bit stiffer because of the weight and spring rate, but will it sit pretty?
