- Aug 6, 2009
- 1
- 0
- 0
User ID: from other mustang sites: Quick50stng (Corral), ChrisVande ( Street Car Forums & Four eyed Pride)
HO upper/lower intake $20
HO cam $30
Roller lifters $30 shipped
Explorer 19 lb injectors $30 shipped
Fuel rail $10
Bosch O2 extended sensors (new w/maybe 1000 miles) (SOLD)
UPR X-pipe $60
Flowmaster knockoff mufflers w/flow tubes $50
Long block w/o cam $150 (has 230k miles but runs great good oil pressure, new head gaskets, and rear main seal)
ECU from Mark VII $30
Engine wiring harness $30
Injector harness $20 (SOLD)
Distributor $18
FRPP AC delete kit new $20 (pending)
5.0 Timing cover $20 (pending)
Oil pan with pickup $20 (pending)
AOD transmission with converter, flexplate new in 04' $250
Walbro 190 lbs/hr fuel pump $40 SOLD
5.0 HO aluminum valve covers polished tops/painted black on the sides $20
5.0 mustang 15:1 steering rack in good condition with good tie rods Pending SOLD
Stock 5.0 Sport computer $5
HO Throttle body $15
Engine heater coolant tube $30 shipped
Added Parts:
TPS and IAC $10 for the pair (SOLD)
New stock radiator and good hoses $50 (perfect for that 4cyl swap)
Fan shroud in excellent condition $25
Clutch fan $25 no cracks in great shape.
Radiator hold down brackets $10
Take $100 for brackets, radiator, clutch fan, shroud and hoses!
Stock coil and bracket $10
302 Starter (in good working order) $15
Large stock sway bars $10 each
Mustang 5.0 stock front lower control arms (have good bushings) $15
__________________
82 Coupe. 302, Gt40's, Torker289, 3:73's in a 2800 lbs package
88 T-bird Sport coupe 5.0/AOD/3:45 gears
HO cam $30
Fuel rail $10
UPR X-pipe $60
Distributor $18
Added Parts:
__________________
