5.0 Engine Bay
InMy88GT
Active User
Oct 22, 2016
17
image.webp image.webp image.webp image.webp image.webp image.webp image.webp image.webp image.webp image.webp
Just wondering if anyone could help me out and point out anything out of the norm (odd) about my engine bay. Maybe something thats missing, connected wrong, etc. any help is much appriciated.
Also my mechanic says the oil leak by the distributor could be because the seal? Ive read this could be the intake manifold?
The car is a 1988 5.0ho 5 speed gt hatch.
The car was oringally auto but converted to manuel
There's an o ring around the dist. It's usually included in most lower intake gasket kits. Pretty easy fix but you need to remove the dist and restab it correctly and set the timing. However, a more likely cause is the lower intake manifold is leaking oil. I'd grab a lower intake gasket kit and plan on yanking the lower at some point
Also, your dist is not plugged in.
You'll want to plumb up the charcoal canister. Line from rear of car connects to one port and then the line with solenoid connects to front port of intake manifold. I can see the vac line present, but it's not connected to canister
Thank you I unplugged the distributor soley for the pictures purpose
Are you referring to the gold plug in the plastic hose right behind the picture of the charcol canister?
Ill upload another picture
Yes. The vac line connected to that probably runs to the front of intake manifold. If so, connect to that short 4-5" vac line hanging off the canister.
On the other port, there should be a hard plastic vac line running from just behind pass apron to the canister. It comes from the gas tank
^^^ Thank you all, shout out to the stangnet mvps, i always see you guys helping everybody!
@Mustang5L5 Tbh thats what ive been wanting to do. Pull the engine out check everything from top to bottom degrease, clean, wire tuck, and replace all gaskets.
Im giving the mechanic who converted it a call to find out the computor.
@karthief i belive the hose from the tab and tac are broken if thats where you refer i get the vac line from. I pulled a vac hose and connected it to the egr before and i belive it was to much pull because it just shut the car off
