5.0 engine harness
whlte88stang
hey guys whats up? im doin a 4 cyl conversion. i kno u guys here this question a million times but. i need sum help. 1 whats a good site i can have wiring diagrams n vaccum diagrams online. 2 does the engine harness have the oxygen sensor connectors on it. or is it part of another harness. any quick tips on the wiring part would be helpful. everything else i kno how to do. thanks alot guys!
It would be a easier job to do a carb setup...no computer, and all the crappy wiring and cheaper HP. Otherwise, you can pickup most these parts on ebay cheap.
Almost everything you need to know... http://www.veryuseful.com/mustang/tech/engine/
More diagrams...
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
Copied From bbunt302
Just for reference, here's a list of all the compatible years:
89 harness should work for 86-89 as long as you're using mass air.
90 harness will only work in a 90. (B/c of air bags and dual dash connectors)
91 through early 92 harnesses should be compatible (single dash connector, fuel pump relay under driver's seat)
Late 92 through 93 harnesses should be compatible (single dash connector, fuel pump relay under the hood)
Computers from 89-92 are all the same. Look for the A9L sticker on the back cover for a 5 speed that matches your requirements. Example: E9ZF 12A650 AA" with the A9L code.
