5.0 Fuel press regulator
  • Thread starter Thread starter stangman16
  • Start date Start date Jan 22, 2007
stangman16
640
San Antonio, TX
Jan 22, 2007
  • Jan 22, 2007
How hard is it to change out the Fuel Pressure regulator on a stock 5.0 89-93 Mustang? Do I need to take off the fuel rails in order to do so?
I went through the EFI no-start checklist, and fuel does not come out through the opening of the vacuum port on the regulator when 'on' and even while cranking - so I'm guessing it's shot (looks old anyhow & the pump is working).
Are there any special tools required to remove it?
Thank you!
68EFIvert
639
Camas, Washington
Jan 22, 2007
  • Jan 22, 2007
I just changed mine. There are three allen bolts that you can access from the bottom of the fuel rail. Take those out and drop in the new one. Really easy. Do you have a fuel pressure guage? If not you may want to get your hands on one. I think Jeg's sells them for $35. If you need a new regulator I have one the I replaced for an adjustable one you can have for the cost of shipping.
Darreld
91ghp5.0
42
Somewhere
Jan 22, 2007
  • Jan 22, 2007
It really helps if you take off the upper intake. I tried to do it without taking off the upper plenum, and I couldn't get the last bolt. That's on the to do list! Other than that...it's pretty darn simple.
ozanracing
172
  • Jan 22, 2007
That's good. It's not supposed to,. It is, afterall, a vacuum fitting.
stangman16
640
San Antonio, TX
Jan 22, 2007
  • Jan 22, 2007
Posted by: jrichker
"F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect
for fuel escaping while pump is running."
I guess I mis-understood this, so since fuel is not escaping then my regulator is just fine?
88-5.0mustang
  • Jan 22, 2007
yeah it should be just fine.. its shot if their is fuel comming out of the port.. i think that means the diaphram is pooched..
stangman16
640
San Antonio, TX
Jan 22, 2007
  • Jan 22, 2007
goodness... leave it to me to get that backwards. Thank you guys for saving me some money and the headache of changing it out.
back to more diagnosis on the no start (with fuel & spark) condition.
88-5.0mustang
  • Jan 22, 2007
i would still get a fuel pressure gauge on it just so u know what kinda pressure u have going threw the rails
stangman16
640
San Antonio, TX
Jan 23, 2007
  • Jan 23, 2007
Is there one that would work with the stock fuel rail and pressure regulator that you can recommend?
91ghp5.0
42
Somewhere
Jan 23, 2007
#10
  • Jan 23, 2007
  • #10
You can put one on the fuel rail I believe...there is a port on it, if I'm not mistaken. The aftermarket fuel pressure regulator has a port on itself for a gauge. If you have the cash, it's a great supporting mod for later things (HCI/blower/nitrous/turbo).
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Jan 23, 2007
#11
  • Jan 23, 2007
  • #11
NOS makes an adapter for FPRs- that's what I used. Put plumber's tape around it. (teflon)
Oh yeah, you'll have to take out the shraeder valve fitting. There's a tool for that.
Lxpony
355
central mass
Jan 23, 2007
#12
  • Jan 23, 2007
  • #12
It is much easier with the upper manifold off
91ghp5.0
42
Somewhere
Jan 23, 2007
#13
  • Jan 23, 2007
  • #13
Agreed. I still haven't gotten that damn third (farthest away) screw on. I tried to do it without taking off the manifold. Oh well. Maybe this weekend when I'm installing the gauges
Lxpony
355
central mass
Jan 23, 2007
#14
  • Jan 23, 2007
  • #14
I got that one out my cutting down the size of my Allen wrench with my Dremel so there was clearance. It would have been easier with the fuel rail off.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 23, 2007
#15
  • Jan 23, 2007
  • #15
The auto parts stores have gotten better about renting/loaning test tools. I recommend that you check and see if there is a fuel pressure test gauge available for loan/rent. I spent $35 and bought one because it looked like a good tool to own.
The cheap & dirty way is to use a tire pressure gauge, but the acccuracy may be a bit off. Watch out for the squirting fuel if you try the tire gauge...
JChalfan
551
Bellevue, WA
Jan 23, 2007
#16
  • Jan 23, 2007
  • #16
That's what I've done in the past too, worked great. It was really the only way to do it with the manifold still on.
Jeff
rickd93_lx
162
#17
  • Jan 23, 2007
  • #17
j, would dropping a fuel pressure guage offset the calibration of the guage? the reason i ask is most parts stores(franchise) have a bunch of kids who really dont care about there jobs throwing tools around, i was going to rent a torque wrench from a. zone and the guy dropped it from about 4.5 feet up, picked it up handed it to me and said dont worry there tough. i dont trust auto parts stores tools that require precise measurements. just my 2, but if droping a guage does not do the same as dropping a torque wrench themn it would be fine i guess.
  • dan50
  • Jul 18, 2026
dan50
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
J
Fuel Fuel Pressure Issue
  • justadude07
  • May 12, 2025
Fox 5.0 Mustang Tech May 12, 2025
justadude07
J
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
