5.0 main seal question
95&03GT
24
Hey I have a 95 GT with the 5.0 the front main seal is leaking I was wondering are the front and rear main seal the same b/c pep boys dint have it in there system but they have the rear main seal.
and also how hard is it to change out the front main seal? do I have to remove the oil pan?
thanks
:flag: .
Bill is correct. It may also be called a timing cover seal. Pepboys didn't stock it when I needed one, but I did end up getting a full gasket set for the water pump and timing cover that included the seal from Murray's. It's a PITA because the balancer needs to come off (good time to see if it needs replacing if it's a stocker), but the seal swap itself isn't difficult. I had my timing cover off so it was easier, but you should be able to do it no problem in under an hour.
