David, I recall hypers starting ~ two months before the end of the year (sound right?), but whom knows. I do agree with your sentiments. I dont think all that many folk use poweradders and otherwise, having less coefficient of expansion on a DD type rig isnt all bad.
1986 was the first year for forged pistons and in 1986 was the only year the pistons were true flat top pistons (no valve reliefs). Which is great when you slap some E 7 heads on which was what I did and love it.
Resurrecting the dead but.....
All sb's in 86' Mustangs were forged, flat dished pistons, with a flat tappet cam?
The reason they went with the hypers are numerous. first off they are cheaper...thats a big one. Secondly they have a lesser coefficient of thermal expansion. This means that the piston can be more closely sized to the cylinder bore. The piston will not expand as much as it warms up (after cold starts) Therefore there will not be as much piston slap which is a common problem with forged slugs and cold starts. Piston slap reduces engine life plain and simple. So the choice to use hypers for a mild 225 HP V8 wasnt a very tough one.
Hypers arent nearly as bad as everyone says they are. Nearly everyone on this site that isnt running a power added or high compression could easily get away with hypers. The cost savings are fairly significant and for increased engine life on a daily driver, its not a bad idea.
