5.0 stock pistons forgeed?????
Hypers started before the end of the '92 model year run. If the motor is from around that time, make no assumptions.
cenok - Mine did just fine:) No 'piston slap' on cold start-up, and remained tighter in there bores than the forged. Also, they are lighter;)
Black oil pan - Hyper
Gray oil pan - Forged
Yeah somewhere near the end of the 92 build year, they started swapping them...
David, I recall hypers starting ~ two months before the end of the year (sound right?), but whom knows. I do agree with your sentiments. I dont think all that many folk use poweradders and otherwise, having less coefficient of expansion on a DD type rig isnt all bad.
It does ring a bell:), I know you got one of the sharpest memories out there, so will go with it...
Yeah, a forged piston would be a good idea with anything that could initiate some sort of detonation, whether a blown or nitrous'd combo...
OT: I got a pic of the 98, I just got to send it by email now when I load it up, I did it just for you:D
Either way they are both good units. I have the hypers in my Cobra. This is the 4th summer superchaged with countless runs at the track, and no trips back to the tuner. I have 10,000 plus miles supercharged. Tuning is the key to long life.
The reason they went with the hypers are numerous. first off they are cheaper...thats a big one. Secondly they have a lesser coefficient of thermal expansion. This means that the piston can be more closely sized to the cylinder bore. The piston will not expand as much as it warms up (after cold starts) Therefore there will not be as much piston slap which is a common problem with forged slugs and cold starts. Piston slap reduces engine life plain and simple. So the choice to use hypers for a mild 225 HP V8 wasnt a very tough one.
Hypers arent nearly as bad as everyone says they are. Nearly everyone on this site that isnt running a power added or high compression could easily get away with hypers. The cost savings are fairly significant and for increased engine life on a daily driver, its not a bad idea.
+10000000000000000000000000000000000012351235132500000
I agree that many times over. Read my post earlier this year above.:nice:
