- Mar 22, 2007
- 4
- 0
- 0
Hey guys,
Ive recently ran into two different problems with my 5.0.
It is a 4cylinder car, with a Mass-air 302 conversion. Ive been having the issue that maybe twice a week out of the blue, ill try to start the car, and it'll crank really slow, as if the battery is low on voltage. When i let off the key, the solenoid stays energized and continues to crank the car, regardless of key position (or if the key is out all together). The clutch safety switch has been bypassed also. I have replaced the solenoid, but that was to no avail.
Also, this past weekend i swapped on a set of ported boss 302 heads with crane roller rockers. Fired the car up (after realizing i had ignition timing 180 out
) And the car will not 'learn' itself to idle. It revs freely, and smoothly, much moreso than before with the stock heads. Ive checked for airleaks, and came up with nothing. The car will rarely idle, and when it does, it is sparatic, basing out at around 500rpm. Driving the car resulted in a much better 4500-rev limiter pull, with a slightly less agressive idle-3000rpm pull.
The only thing i couldnt recall, was if there was a vaccuum line on the fuel pressure regulator or not. I tried it both ways, and came up with nothing.
Any thoughts or ideas would be greatly appreciated. Thanks guys.
Chris
) And the car will not 'learn' itself to idle. It revs freely, and smoothly, much moreso than before with the stock heads. Ive checked for airleaks, and came up with nothing. The car will rarely idle, and when it does, it is sparatic, basing out at around 500rpm. Driving the car resulted in a much better 4500-rev limiter pull, with a slightly less agressive idle-3000rpm pull. The only thing i couldnt recall, was if there was a vaccuum line on the fuel pressure regulator or not. I tried it both ways, and came up with nothing.
Chris
