5.3l lsx in 65 stang
Or an SHO? I was looking forward to seeing that. I agree that a 351w is really too tight in a 65-66. There is not a ton of room in my 67. I am currently changing my T-70 out for a Borg Warner S475. Wanna talk about no room. I also agree that a big down pipe under the cross member could be a problem. Mine will split from 5" into a pair of 3" pipes, one on each side of the motor and under the cross member. I ran it last summer with 2.5" the same way and not tucked very well and never hit it on anything. Most long tubes hang down just as low at the collector. I have had more trouble with long tubes dragging speed bumps when dropping the front tires off it.
it still gets on my nerves that that engine was stolen....so I had to restructure....in all honesty the SHO engine was as tight a fit as the 351 anyway, maybe worse...ah well, the 4.6L I can actually get parts for...
If you have access to the LS stuff cheap..........do it!!! I think it is great to tweak those guys who have a bias.....I'm twisted like that.
There is a guy in town with a show-quality 67......with........a 440 in it. It rocks!
Different isn't necessarily bad.............just different. If people never tried it then we would all be driving bland slow boxes. I get it...........good luck with the build and keep us posted.
longest post ever
No way im gonna be able to fit a turbo'd 351 between the 65 shock towers.
Its hard to include the cost of the Mustang II into the swap because it would cost about the same to add a nice brake and suspension setup, plus i already need to do something about my super loose power steering setup.
Another thing i like about the LSx based engine is the ease and price of going the 6 speed route
To build a comparable 351 its gonna cost about
shortblock- $750
Heads- $800 at the least
cam- $200
roller lifters are super pricey- $350
Intake manifold- $150
Carb- $400
MSD 6al 2- $350
Head studs
Main studs
gaskets
the list will go on and on
I'd say if your sitting anywhere around $3k you'd be sitting pretty well. i think $3500 is more reasonable
I have recently started thinking about going carb'd blowthrough setup rather than FI, just for sake of install, although it adds about $500 to the bill. I havent decided quite yet what route i'll go.
LSx Cost Breakdown
Engine
5.3l longblock- $500
Edelbrock vic jr. carbed manifold- $289
MSD 6010 LSx ign. controller- $300
Holley 750cfm DP setup for blowthrough- $400
ARP rod bolts- $100
Figure $500 for all the other misc stuff to get engine to run
$2100
Turbo Kit
Borg warner S400 turbo- $595
Hot and coldside- $500
Blow-off valve- $250~
Wastegate- $250~
Oil feed + return- $50
misc. parts- $200
$1900
Mustang II
Crossmember- $300
Tubular control arms, coilovers, dropped spindles- $1380
Includes your choice of upper control arms (Std. or 5/8" narrower), offset strutless lowers (Std. or 5/8" narrower), new standard or 2" dropped spindles, new standard chrome springs and shocks, air springs or coilovers, rebuilt power rack & pinion with bushings and new tie rods. 11" brake kit.
$1700
Under $6000 for 550+ horsepower and a complete new front suspension and brake package. For now this is the route im going to plan on, but things could easily change. Order of tasks to be done on my car: complete the back half thats been started, next is the Mustang II, then it will be motor time.
you have to be kidding, theres no way you are going to fit a turbo lsx in there any easier than a 351w....oh, and unless you are shooting for more than 600HP, theres no reason to replace anything other than pistons in a 351w, maybe rods, as for the rest of the engine....in a turbo application stock is fine, up to 600HP anyway, possibly more....I learned my lesson in wasting money in turbo builds with the 4 2.4L neon engines I built, throwing money at head work is a lot less effective than throwing money at the block to take more boost, and if you think you are going to get away with a oil feed/return for $50 that doesn't leak you're smoking crack...another area I have planty of experience....the only thing that ever worked right for me was SS lines and an aluminum oil pan with the return WELDED in. that being said, in all honesty carbs and turbo just dont go together for best efficiency...stay EFI, you get so much better control...take the $400 from the carb and spend it on Megasquirt....a v3.0 board with a MSII chip would be ideal, you are also forgetting the cost of wideband ($250 for the AEM unit, it works awesomely and comes convienently packaged in a gauge) so again....you aren't getting it done any cheaper,1/4" is just not any more room to run stuff...that only translates into 1/8" per side. there's a ton of stuff you just don't need to do if you are going turbo as far as engine prep....my suggestions on engine prep whether its an lsx or a 351w would be, rebuilt, forged pistons and rods....good head gaskets...and that's it, the turbo will take care of the rest...take my advice here...I wasted so much money on stupid things on my first 2.4L turbo build....porting, polishing, stainless valves, 3 angle valve jobs, cams, etc etc, it was stupid....later engines of mine made a lot more power with a ton less invested...the main reason being that the first engine I built had pretty primitive fuel controls(like a carb as a matter of fact, same basic idea) spend the money where it will actually have an effect...EFI and more boost, I do approve of the mII front suspension though, it makes it so much easier for turbo, my 4.6L will eventually be turbo...low boost,stock internals, aiming for something like 450HP, however I've decided that can come later, I have enough challenges getting it in and running
I was just saying theres no way to turbo the 351 without the mustang II, same with the LSx.
And as for all the carb stuff i have not decided which way i wanna go, i know i could get the fuel injection setup for about the same as i would dump into the blowthrough setup. For some reason i just dont get the hang of MS, but then again i dont know much about efi tuning at all.
I dont plan on opening up the 5.3 except for adding the rod bolts, just for insurance when i rev it out, peace of mind is a good thing.
I have decided to sell some things that i had bought for my 302 turbo buildup (DSS main girdle, MSD dizzy, and a weiand excelerator manifold) to put towards the purchase of either a 4.8l or 5.3l LSx motor.
Got high hopes for you, but don't think it'll happen with that budget. Just because of all the things you can't see yet, and the 1k in fuel system you need on top of all you've thought of already. 600 HP non inter cooled will be pretty tough. So an IC or meth will cost ya. But good luck either way.
so you're going turbo.....other than being different have you given a reasonable reason to use a LS1? I personally think it would be neat to see, but I'm a very practical guy, its not going to be cheaper, and you will never get much respect simply because you went and put a chevy engine in a classic mustang....the message this sends to other mustang owners is that you don't think a SBF is good enough for you, it makes you seem like a LS1 snob(not necessarily what I think, but it is the message you are sending). Go for it though, but keep all your reciepts and a log of your time and add it all up for us afterward...after all time is money too.
ive decided to hold of on any of the engine build until after i'm done with the chassis and re-wire? its getting a mustang II regardless so i'll just go from there- and thanks to those of you who have come around and given me a lil' support
