5.4 3v ported/modded intake manifold
Interesting design! You might wanna invest in a powdercoating gun http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94244 then go buy an old/cheap electric oven from salvation army or a used appliance place - will make your pieces look OEM and have a nice even finish (plus it protects the metal, and will last ALOT longer than paint).
You should spray for the track, that would be AWESOME :nice:
of course it's ugly.
it flue gas hose not dryer hose. heavier duty.
it will have to do until i figure out something to look better. i need dyno number for now. better looks come with better dyno numbers. why make it pretty if it fails to perform?
the shape has little to do with dynamics. the inside is 1/4" thick and shaped like a trumpet. good enough. certainly better than the stinkin PP elbow?
if it fails RR plates and 4.6 3v intake is up next. that will work.
ok i finally went to the track with exactly the same setup as this spring with the twin 57 on it. conditions were pretty much identical. 72 degrees RH 68%.
03/30/2007: 60'-2.1028 330'-5.9690 594'-8.56 1/8th-9.1520 @ 77.29mph
10/30/2007: 60'-2.1030 330'-5.8930 594'-8.44 1/8th-9.0109 @ 79.09mph
i have to lift for the 2-3 shift to avoid the limiter so the mph is off. with a program fix i expect 2 mph more
__________________
