  • 2005 - 2009 Specific Tech
5.4 short block?
  • Thread starter Thread starter ranger04
  • Start date Start date Aug 29, 2007
R
ranger04
245
  • Aug 29, 2007
Can the 5.4 short block be transplanted into our cars while keeping the 4.6 heads, intake and so on? It seems like it would be an easy and cheap way to gain some cubes. I know there doesn't seem to be an advantage in swapping in the whole motor at this point, as the 4.6 and F-150 5.4 make the same hp. So the 4.6 has been tuned to run, more so than the 5.4. However, if the 5.4 short block could be swapped in, that would give us more cubes and torque if nothing else.
T
TGJ
1,049
  • Aug 29, 2007
The heads will swap, the intake will require a spacer. Personally I wouldn't do this swap. The 5.4 block is cast, the 4.6 block in the 05+ mustang is aluminum. You will be adding a fair bit of weight to the front with the 5.4. You will be losing high RPM HP as well, if you are staying N/A 3V.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Aug 29, 2007
  • Aug 29, 2007
I agree. The 5.4 is the exact same as the 4.6 except a little wider and a MUCH longer connecting rod, giving it the extra displacement. Without exotic internals (like the Ford GT), the RPM is really cut, like redline at 5000. You will gain lots of torque, but it would more then likely be slower due to the RPM capability and high RPM horsepower.
anthony05gt
1,262
Maryland
Aug 29, 2007
  • Aug 29, 2007
Agreed!
K
khendrix2374
25
  • Sep 1, 2007
Redline at 5000?!?!
No.
My supercharged 5.4 will spin up to 5600 at shift... not redlining.. but at "MY" shift point.
granted.. you will add weight.. but not a LOT.
I'f you want more cubes.. there are kits available to increase the stroke on your 4.6 to 300CI. while retaining your stock heads.
Stroke it out to 300.. plus ported heads+ cams+ blower+ forged connecting rods and pistons and your golden to more HP tan you really want for a street car.
T
TGJ
1,049
  • Sep 1, 2007
khendrix2374 said:
Redline at 5000?!?!
No.
Supercharged cars are different than N/A cars. Even ported 3V heads do not flow enough air in N/A trim to support the issue of high RPM horsepower that a stroked or 5.4 motor have troubles making. Superchargers/Turbos overcome this as they add forced air. A SC'd or Turbo'd 5.4 should make power upto 6500 RPM easily.
G
Supercharger Options 5.4 32V Intech
  • Germangazguzzler
  • Apr 19, 2025
  • Other Auto Tech
Other Auto Tech Apr 23, 2025
RaggedGT
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
