  • SN95 4.6L Mustang Tech
5 liter based engine in 99-04 stang
  • Thread starter Thread starter Jch461
  • Start date Start date Dec 25, 2008
J
Jch461
  • Dec 25, 2008
Ok here is my situation right now. I know where there is a wrecked 03 mustang V6 that wouldn't take much work to fix aside from a small tug on the frame machine to straighten it out and some new parts. I also have the ability to buy a 306 engine out of an 89 Notch that carried the notch to high 10 second/low 11 second slips consistently.
The engine is carbed so there won't be any swapping over any electronics.. just a bolt in. The stang is 5 speed and i'm sticking with the 5 speed trans that is on the 306 in the notch.
So my question is.. will a.. say a 94-95 tubular K member bolt right in to the 03 chassis and allow the engine to drop right in? what about a 94-95 transmission crossmember? would it be even close? Now im not an expert on Mustangs but I ask that because I'm pretty sure that the 4.6 mounts are different that the 5.0 in the earlier GT's.
joshjwc9
1,095
17
39
Palm Harbor, FL
Dec 25, 2008
  • Dec 25, 2008
Now MM sells a pushrod Tubular K for 96-04 cars for cheap, and I bet that a UPR setup can be made if you are on a budget...
mustangman9812
661
Mars Hill, NC
Dec 25, 2008
  • Dec 25, 2008
Buy the 5.0 Tubular K-Member for a 94-95. But you will need a Different Bellhousing as Tranny will not fit the 5.0
J
Jch461
  • Dec 25, 2008
The 306 is going to come with a beefed up T-5 (it's either the tko 500 or 600). I'm getting it too. so will the 94-95 t5 transmission cross member make it a direct bolt in with the K-member?
BurningRubber
1,865
24
58
Dec 25, 2008
  • Dec 25, 2008
Gonna run into computer problems with the digital odometer, speedometer, and tach.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Dec 25, 2008
  • Dec 25, 2008
it will have to be a track only car. there will be no way to pass an inspection with a carbed engine in an 03
Mossberg
ATL, Shawty
Dec 26, 2008
  • Dec 26, 2008
Hopefully he lives in a state that has no inspection requirements if he wants to be street legal.
squeak93
2,348
417
164
Joplin, Missouri
Dec 26, 2008
  • Dec 26, 2008
It is quite do-able. Just like above, tubeular K from a 94-95, ur 94-95 trans cross member should work or u may have to buy one of the adjustable ones they use in a 6 speed swap (I think u can grind ur spot welds on the stocker but don't quote me on that).
U can buy a guage panel insert and cut out for ur own gauges and by pass all of the crap factory stuff ur going to want to upgrade anyway.
Good luck. Sounds like it would be a fun project.
J
Jch461
  • Dec 27, 2008
Your right. I don't. That will not be a problem. I wouldn't even think of this project if I did.
And the poster above read my mind above about just cutting a custom gauge panel to put in some good autometer stuff. I know a guy that has access to a waterjet machine every now and then that can cut me some stuff out of billet aluminum.
I'm going to drive the car on the street a lot and the only thing that I have decided that I may have to do without is air conditioning. That is unless I can find a way to make the early compressor work with the newer stuff in the dash... if that's even possible. I'll have to consult some HVAC people on that.
Thanks for the info guys.
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Progress Thread Dirty Water Racing 89 Notch Project
  • ShedBuiltMS
  • Sep 29, 2020
  • 2 3 4
14K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2021
Flyboy60
F
Engine 1988 LX 5.0 shaking violently and popping under acceleration - video inside
  • lepryy
  • Sep 19, 2019
11K
Fox 5.0 Mustang Tech Oct 8, 2019
lepryy
