I'm looking to find a spare in a junkyard that I can use in my 1969. Does anyone know if the new bolt patterns are the same on all current Fords & will they fit on the 69's? What about the Taurus rims?
RGS0907 said:I'm looking to find a spare in a junkyard that I can use in my 1969. Does anyone know if the new bolt patterns are the same on all current Fords & will they fit on the 69's? What about the Taurus rims?
degins said:Fitting a wheel is more than just bolt pattern. You must get the backspacing right as well. To state it simply, wheels from Classic Mustangs have moderate backspacing, they are dished in. Modern Ford wheels have large backspace and have very little dish to the front surface. The inner rim of these wheels would interfer with the control arms or spindles.
5.0ina66 said:Ranger/Explorer/Areostar are ~4" backspace and usually 15x7. Only ones I'm aware of with the proper backspace.
yeloxr7 said:Crown Vics, Grand Marquis and Town cars up to about 2003 have wheels that will fit. Many have space-saver spares.
Taurus/Sable/Continental(FWD) and Thunderbird/Cougar/Mark VIII (89-96) have a smaller bolt pattern (5x4 1/4') and will not work. Offset/backspace on these would not be workable anyway.
John Z said:You want to be sure the inflated height of the car is the same as the tires on the car. Otherwise you can screw up the rear end in a few miles.
The spare whether full size or donut has the same inflated diameter as the stock tires. Other wise one end of the axle spins at a different speed than the other end.RGS0907 said:I never heard that. What do the cars that come with donuts do?
RGS0907 said:Hey, that's what I needed to know! I'll hit the local junkyard this Saturday & look for a big Ford/Lincoln up to 2003.. Thanks. Otherwise I'll go with the 14x5" idea with a C78 tire.
RGS0907 said:Well, I tried a junkyard spare from a big Mercury today. The bolt pattern is very slightly off & I couldn't get it on my 1969. I even had a bolt pattern drawing with me & the spare was so close that it looked like a match... Any suggestions? Is there a specific vehicle that I should be looking for to match the bolt patterns?
