5 lug conversion MC ?
  • Thread starter Thread starter sweet88gt
  • Start date Start date Jan 14, 2006
sweet88gt
334
Venice FL
Jan 14, 2006
  • Jan 14, 2006
Ok, I just got the car alignment done today and was testing the brakes out. I have 95 spindles and calipers up front and ranger axles and drums out back. The car doesnt seem to stop any better than before. I havent changed the MC or booster yet. I have ordered a 95 MC and booster and its on its way. Shouldnt the car stop marginally better than before?? My buddy has an 85 GT and did the same swap and his car stops alot better than mine. I'm thinking that has something to do with his MC stock being a 2 port design and mine stock being a 3 port design. If I change to the 2 port design MC and leave the drums until funds are available this should solve the problem correct?? I'm looking for some suggestions. Thanks
P
PRO50SC
1,012
Olney, Maryland
Jan 14, 2006
  • Jan 14, 2006
How does the pedal feel. Firm or soft? Maybe you need to bleed the brakes again. Are the rear shoes adjusted up so there is just a little drag on them?
sweet88gt
334
Venice FL
Jan 14, 2006
  • Jan 14, 2006
Pedal feels soft to me. I dont like it at all. I bled the brakes once and took it for a ride and rebled them to double check. The back brakes are adjusted with slight drag.
vristang
4,933
101
124
Seattle
Jan 14, 2006
  • Jan 14, 2006
I think I misunderstood...
Changing from 4 lug to 5 lug would not affect braking performance.
If you changed the rotor size, then you would see a change.
Maybe you still have some air in the lines. Some times it is a real pain to get the air out.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Jan 15, 2006
  • Jan 15, 2006
It does if you change the calipers.
He is right about needing a new MC.
With the 95 calipers up front, you would want to upgrade to a '93 Cobra 1" bore MC.
However, if you plan on swapping to rear SN95 disks you might be better off locating a 94-95 GT/V6 MC and using that instead.
That MC might work as well if you get a set of 99-04 dual piston GT PBR's and run them.
Optimally though the 1" bore is what you want
SVOconvLX85
251
Vegas, for a while...
Jan 15, 2006
  • Jan 15, 2006
I have sn95 stuff up front and an 85 SVO rear disc conversion in back. My brakes work fine but I feel that they could be better. I kept the stock MC and the svo had a totally different one with an actual cover and not a cap. The svo came with the same one they put in the 93 cobra I believe. There is a site out there that has a lot of good brake upgrades and needed supplies. Just search google for mustang brake upgrades.
sweet88gt
334
Venice FL
Jan 15, 2006
  • Jan 15, 2006
What I should have said was that I feel the brakes are slightly worse than the stock 4 lug. I have the 95 calipers up front and I thought they have a slightly bigger piston than the stock brakes. My thought was with a bigger piston in the calpier it should stop better than before. I am planning on running 95 brakes in the rear, so I order 95 MC and booster. My understanding is I wouldnt need the larger booster unless my camshaft wasnt pulling enough vac. Otherwise I could change the MC and retain the stock booster. Does that sound right?? I wish I could find a 93 cobra MC because it is the all around best for the bore size. If I planned on running 13 cobra brakes up front and 11.65 out back what are your thoughts about the MC and booster and what else could I be missing?? Thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 15, 2006
  • Jan 15, 2006
See http://www.svo73mm.cjb.net/ fir brake help.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Jan 15, 2006
  • Jan 15, 2006
If that is your ultimate goal, you want either a 94-95 GT/V6 MC or a 94-95 Cobra MC.
Booster is optional, but more than likely you will need it so i recommend installing it from the start.
Make sure you factor in the mods to the prop valve...ie gutting the stocker and adding an adjustable
www.sn95brakes.com
sweet88gt
334
Venice FL
Jan 15, 2006
#10
  • Jan 15, 2006
  • #10
www.sn95brakes.com
Yes that in the end will be the goal, but for now stock 95 brakes will be a good upgrade. I plan on the supercharger soon and the stock brakes were scary. At the track I have to ease into the brakes and wait for the last turnoff. I was never happy when my e350 work van loaded down will stop just as good as the mustang. Thats just not going to cut it anymore.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
  • dan50
  • Jul 18, 2026
dan50
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Granada Front Disc, 9” Drum Rear, 86 Bronco II MC, and Manual Brakes - Pedal Slack
  • AeroCoupe
  • Jul 8, 2023
2K
1965 - 1973 Classic Mustangs -General/Talk- Jul 14, 2023
AeroCoupe
