5 lug conversion on a fox?
shifterpilot5.0
49
I just put spindles, hubs, rotors and calipers off a 97' v6 car on my 89' fox.
I want to know if I can up grade now to a 13in rotor with cobra calipers and a 13in rotor from a 98 cobra.
Is it all interchangeable? :shrug:
yes it is, but i think you might have clearance issues with the 97 spindles, as they are a bit wider than the 94-95 units.
the tire might rub the top of the fender opening. Just a heads up
In addition to the cobra calipers and rotors, you'll probably want to use the cobra softlines as well. I'm pretty sure that they have a larger diameter hole to flow more fluid.
