5 lug conversion ?'s
ONEBADPNY
195
FREMONT, NEBRASKA
i found some 5 lug rotors on ebay that say you can convert to 5 lug with no other modifications. i will try to post a link. i know i need different axles too but i am going to stay with drums for now. are sn95 axles out of a 94-95 the same length? not to concerned about a high dollar setup right now. the auction number is 2448279616 sorry don't know how to post link
if your looking for a cheap conversion you can get an 8.8 posi
out of an aerostar van but it has to be an electronic 4wd rig
it has the 5 bolt pattern axles in it and you can use the whole rear if it
isn't worn out. bolts in.
The drivers side of the axle housing is shorter, therefore the pumpkin is offset to the left....
And don't they use leaf springs?
I've never hear of this, but it doesn't sound like it will work
It wont on the 4 link rear.
You can only use one axle and it has to be out of the 7.5 rear end.
