I'd rethink this purchase, the correct spindles for the swap are from a 94/95.
Ya, you can make others work, but at the expensive of different rims.
Also attempt to do the rear with fox length axles, not 94 or newer ones. The newer axles track wider and also cause rim fittment issues.
IMO, just piece it together yourself.
If you can't afford all the good stuff at once, do the front first, then do the rear with ranger axles and drums until you can get the proper parts for discs.
