5 lug conversion , what wheels ??
94-97 Cobras fit
Also:
All V6 wheels
94-98 16" Waffle star wheels
94-95 17" GT tri-bars
'95 Cobra R's
Supposedly bullitt and mach 1 wheels will bolt up, but you'll need to grind the hub a bit. Also the center cap won't fit with the bullitts. Try these rims at your own risk
It's not a clean bolt on. Some guys have made the bullitts work with the Mark 7 rotors with spacers and a little grinding. But i prefer to not consider this a good idea.
In my opinion, if i need to grind, or modify a wheel or brake in any way to make it fit, it's unsafe and i don't want it on my car, so i tend to NOT recommend it to others...so perform at your own risk.
Don't be so cookie cutter with your wheel selection. My opinion would be to sport the cash and get a custome set of 3-piece anything wheels...whatever strikes your taste. There is a new set of SALEEN speedline or STERN wheels over few weeks on Ebay....sure, they're expensive but they hold their value and increase in value as they get harder and harder to find. It's worth it.
You can run any rim you want on a lincoln rotor, and it doesnt require any grinding. You only need 7/8ths spacers and a slightly longer stud. All the parts are like $50, and I have been doing it for a year now. I have 99 cobras on Lincoln rotors. It is sporting 235 tires and it doesnt rub at all with lowering springs. Nor does it stick out of the fenderwell at all.
You can buy the rear axles new from Summit for $190
I forget the kit. It's the FMS 5-lug drum kit. It comes with two ranger axles and two drums.
$200 for rear drums and i'm sure you can get the SN95 stuff up front for about $200
$200 for the upfront sn 95???? WHERE??? I have been looking for quite awhile now and the closest I got was $250..... I live in Hawaii so shipping is outrageous for heavy items...
94-98 's wont work since they are different (I think they pulled the wheel locations in) $275, that was for everything you needed to install them?? I mean, I could get the brackets, spindle, hub and calipers for $250.... but all the small things you need cost extra $$$ tooo
