5 lug conversion! will this work
robertdeuce
147
im want to put some saleen rims on my 89 but i heard that i need to do a 5 lug conversion. i found this on latemodelrestoration, there are 2 kits, i need to know which one i need.
here is the link for the rims, 94-04 Black Chrome S-Style Wheel NT555 Tire Package
will those rims fit this conversion kit
1987-93 Mustang 5 Lug Conversion Kit w/ 31 Spline Axles by 50resto at LRS - Same Day Shipping!
or
1987-93 Mustang Complete 5-Lug Conversion Kit with 28 Spline Rear Axles at LRS - Same Day Shipping!
The rear setup should work I am almost positive the front will not because the hub being too large, I believe that 5-lug front setup is the same as the Lincoln rotors and I have seen a couple threads where people have modified them to work with those wheels. Avoid the headaches and go with SN95 Front spindles for the front. You open up a huge selection of wheels going that route if you ever decide to change.
+2, even more desirable (to me at least) are the cheap very good brake upgrades available when you go this route.
so just the rear will work? theres another product on the site that is just the rear, do i need anything else for the rear conversion than what is in the link?
1979-93 Mustang 5 Lug 28 Spline Rear Axles, Pair at LRS - Same Day Shipping!
do i need to add something? or should this be good . i dont know anything about mechanics.
thanks
yes they will work.
you would need to decide what rear brakes you want to run either drums or disc's. For my setup I'm running Ranger drums but would eventually like to run Cobra Rear Disk. If you plan on running disc you would need to get the appropriate brackets. The link NikwoaC supplied is basically all you need. GL!
thanks
I just finished up installing these axles, but I got the kit with new 5 lug drums as well. They come with the wheel studs so all you need besides that would be the gear oil and I would install new axle seals as well for good measure. I had no issues at all with the parts everything installed smoothly.
