5 lug conversion
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
I am think about doin a 5 lug conversion because im goin to make replica 93 cobra R's from the 17" 94-95 gt wheels.. and i have a few ?'s. what could i use off of a 94-95 V6 mustang? the junk yard i looked at near my house today has 3 off them with everything. And will i beable to use the stock break line? Help is appreciated. Thanx
You need the front spindles off those 94/95s. You can swap the entire rear if you want or just take the parts. Then you need to read up on gutting your prop valve and adding an adj one, getting a new M/C and Booster, ect.
I like tri-bars!! Lincoln rotors onthis one.
You won't be able to use your brake lines totally stock. If you go with 4 wheel disc brakes and use all the brake parts from the 94-95 Mustang, you will need an adapter for the pass. side front brake line. If you do the rear disc as well, you will have to either rebend the lines that run along the axle tube or you will have to get some custom bent lines. I did a quick write up of my conversion on my website. Check the sig.
good choice on wheels, will be interesting to see what they look like on a teal/green car.
here is the best pic i can find of what my car USED to look like before i went to wider wheels.
