5-LUG CONVERSION
  • Thread starter Thread starter chargedpony
  • Start date Start date Sep 26, 2006
C
chargedpony
53
  • Sep 26, 2006
Im gonna get some moser 5-lug rear axels but what parts do I need and where can I get them to convert the front to 5-lug. I really dont want to use junk yard parts. Am I able to keep the same front spindles and just replace the front rotors. I'm clueless.
Flavadave4
1,044
21
49
Utica, NY
Sep 26, 2006
  • Sep 26, 2006
Try reading through this
http://mjbobbitt.home.comcast.net/index.html
and this
http://www.angelfire.com/ny2/jason/
Juiced88Coupe
367
Austin, Texas
Sep 26, 2006
  • Sep 26, 2006
Or try a search, this is asked about 10 times a day.
GSP393
217
Orange County, Texas
Sep 26, 2006
  • Sep 26, 2006
You can get sn95 spindles and rotors to make it happen.
C
carlp
59
  • Sep 26, 2006
Unfortunately junkyard parts are the way to go. SN95 spindles from a 94 or 95 are what you need for the front. There are 5 lug conversions that just change the rotor, but you are limited by the type of wheel you can use. If you are going with changing the spindles, you will have better sealed bearings and marginally better brakes.(you will need the spindle, the rotor, the caliper, and you should get some new stainless brake lines.) Also, as stated previously, you will be able to run just about any wheel.
Check this link out. You will learn more than you need:
http://sn95brakes.com/5lug.php
C
chargedpony
53
  • Sep 26, 2006
Thanks guys I aprecciate the help and info.
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
A
90 Fox 4Lug rear convert to 5 Lug
  • adimice
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
limp
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
