5-LUG CONVERSION
chargedpony
53
Im gonna get some moser 5-lug rear axels but what parts do I need and where can I get them to convert the front to 5-lug. I really dont want to use junk yard parts. Am I able to keep the same front spindles and just replace the front rotors. I'm clueless.
Unfortunately junkyard parts are the way to go. SN95 spindles from a 94 or 95 are what you need for the front. There are 5 lug conversions that just change the rotor, but you are limited by the type of wheel you can use. If you are going with changing the spindles, you will have better sealed bearings and marginally better brakes.(you will need the spindle, the rotor, the caliper, and you should get some new stainless brake lines.) Also, as stated previously, you will be able to run just about any wheel.
Check this link out. You will learn more than you need:
http://sn95brakes.com/5lug.php
