5 lug conversion
  • Thread starter Thread starter bullitt774
  • Start date Start date Jan 24, 2007
bullitt774
24
  • Jan 24, 2007
i have a '89 4cyl coupe and was wondering if the spindles are the same as GT/LX 5.0 spindles. i found a REEEEEEAL cheap front conversion, and want to get it while the getting's good. ya know?
K
krallman
96
Hurricane, WV
Jan 24, 2007
  • Jan 24, 2007
No the spindles arent the same. I think the 79-86 v-8s as well as 79-93 with the four cylinder have the same spindle. So those years have the same spindles. The cheapest way to go to 5 lug with your spindels is to get 83 to 90 something 4-cylinder 2wheel drive rangers rotors. Pick 85 to be safe. Thats what i used on mine and you dont have to change anything. For the rear i would go with a 94-96 rearend. I think they are a little longer but it would be the easiest direct bolt on. I found a 8.8 rearend from a local junkyard for 250 bucks.
bullitt774
24
  • Jan 25, 2007
ok, i like the ranger idea, but the rearend is gonna be a 9" so that is arleady been taken care of. now if i wanna upgrade to drilled and /or slotted rotors with bigger calipers, do i buy the stuff for the ranger then or am i going to be better off buying diffrent spindles at that point??
this place is a WEALTH of information!! ROCK ON!! you guys should think about starting your own website...... oh, nevermind.:SNSign:
P
PJB
131
Rotterdam, NY
Jan 25, 2007
  • Jan 25, 2007
Id buy '94/'95 Mustang spindles and rotors and calipers.
Thats what I did. V6, GT and Cobra spindles are all the same.
The setup you have now isnt really upgradable but the '94/'95 setup is. You can upgrade to the '99+ PBR calipers if you want to.
For now Im going to use the stock '94 calipers and good pads and slotted/drilled rotors.
bullitt774
24
  • Jan 25, 2007
really?? and the ball joint and tierods bolt up the same?? huh, well that solved it for me right there. thats so easy "even a caveman can do it"
thanks bro.
P
PJB
131
Rotterdam, NY
Jan 25, 2007
  • Jan 25, 2007
You will need a spacer or washers totalling .330" to make your balljoints work. It goes under the castle nut.
I got mine from www.breezeautomotive.com
It was less than $6 shipped for two spacers (one for each side).
Tie rods stay the same.
88LX
327
Chicago, IL
Jan 25, 2007
  • Jan 25, 2007
here is where most of your questions will be answered:
http://www.sn95brakes.com/
bullitt774
24
  • Jan 25, 2007
nice, thanks a lot fellas. you dont know how much easier you guys made my job on the 'stang.
i just wish i could give back as much info as i have gotten over the past 3 days.
thanks and ill be a lifer to 'stangnet
Supersonic G.T.350
26
  • Jun 8, 2007
you can also change out the lower control arms so that you don't need the spacer, or just change the balljoints to the newer style which is what I would do.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jun 8, 2007
#10
  • Jun 8, 2007
  • #10
You really should upgrade to the 99-04 PBRs as the Stock 94-98s are heavy and not much better than Stock Fox Calipers.
P
PJB
131
Rotterdam, NY
Jun 9, 2007
#11
  • Jun 9, 2007
  • #11
Eventually I might do that.
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
Fox Traction control
  • Sparky714
  • Nov 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 23 minutes ago
FastDriver
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
